Josh P's new 1994 Aerostar.
zenish
charlotte nc
1991 aerostar xlt
come on josh.i need a 351 in my van...:D
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
Move the gas pedal about 3 inches to the left, same with the brake pedal and widen the tunnel. It would slide right in.
zenish
charlotte nc
1991 aerostar xlt
a 302 should be enough.or a 347 302 stroker....
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
How is this project coming along?
Not much to update on this project yet. I'm working on rebuilding the axle I pulled out of my other van. I'll do the same to the rear of this van and get some new springs. What makes it difficult is I can't pull the front subframe out with it sitting in my driveway for the long term work I need to do on it. City code enforcement would give me a citation. I may search for a 2wd subframe to set under the van so it looks complete while I work on it.
92exp4x4
Covington, Kentucky
92 XL 2-door and others
Sometimes it's such a PITA to be a car guy. I went through the same stuff at my last house. I understand the thoughts behind it, but it can be frustrating. I'm definitely gonna keep checking back on this project.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
I get it too, no one wants to look at a car in pieces for months or longer. Since work has been slow for the last few weeks I have extended my driveway down the side of my house to the backyard. I still need a fence or gate on the side of the house so the vehicle can't be seen from the street once I roll it to the back. I've still got a couple projects ahead of this one, building a shed and replacing the roof on my house.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
I got the parts off the silver van. The springs, brakes, etc were for this van, I had used them on the other van. I'm slowly rebuilding the 8.8 axle I am going to use. Once I get the axle complete and painted, I will post pictures. The only thing I'm missing is an engine.
zenish
charlotte nc
1991 aerostar xlt
north carolina no longer requires inspections on cars older than 30 years so swapping in a bigger engine sounds very appealing.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
I agree, I'm still gathering parts for this build. What engine would you swap into your van?
zenish
charlotte nc
1991 aerostar xlt
gm lsi seem to be the preferred engine for swaps although oil pan clearance othen makes the decision for you.and width.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
LS swaps are popular. A 302 would be easier.
zenish
charlotte nc
1991 aerostar xlt
i glanced under the hood while doing my daily refilling the radiator.the 3.0 barely fits under there.i don't see how a v8 would fit without moving the firewall several inches.
zenish
charlotte nc
1991 aerostar xlt
im wondering how much wider a 4.0 sohc is than a 4.0 it might fit.55 more hp and might bolt in to the mounts and trans.wiring would be a problem.
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
The 4.0 sohc is wider than a 5.0, more bolt ons, transmission choices and reliability with the V8.
zenish
charlotte nc
1991 aerostar xlt
i really like my aerostars and im hoping you will post a viable power source to keep them on the road.with lots of details.
zenish
charlotte nc
1991 aerostar xlt
my extended four liter van is now a five cylinder because of a broken lifter.im surprised of how much torque it still has.if it wasn't SUCH a bitch to work on id swap in a hotter cam and later closed chamber heads with dual exhaust with dual high flow cats.[my van is now inspection exempt].
Josh P
Shaggin Wagon
Phoenix Az
1991 aerostar
Headers don't fit very well, I had to use a hammer to get enough clearance. I did like how it ran above 4k rpm. It was fun rowing through the gears bouncing off the rev limiter. If you were to swap engines, what would you choose?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
