Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
JoshC's SAS #2
- Thread starter JoshC
- Start date
Add an avatar, upload photo attachments, and more!.
stuntman
- October 23, 2006
- Ridgecrest, CA
- 1994 XLT
I agree with FROADER.What about using the links you already have and fabbing mounts on the FW axle? Jefe has the same arms/links and has mad flex!
Why dont u lengthen your arms? Seems like it would be pretty basic.I could but man mine are so freakin short, like 28" or something.
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
- 1998 Ford Explorer
I agree...it would be just as easy to make new ones.
JTX
- April 24, 2003
- New Mexico
- 94 xlt
Josh nice build man! I just saw your using a quick lok in the dana 40.. After my experience in moab i wouldnt recommend using it. I had maybe 3 miles on mine before it crapped. Quick Lok+35's=Quick POS...
JoshC
Only rolled it once honey
- May 1, 2000
- Culloden, WV
- 97 4d OHV
Well that sucks. I guess i could just use it for the time being until i get it running again. Looks just like a lock rite which i've ran in that D30 for years now with no problem.
JTX
- April 24, 2003
- New Mexico
- 94 xlt
Yeah i was pretty dissapointed with it.. Just makes a bunch on nose.. It should work for a while, Moab may have killed mine faster due to the rocks. Ill try and find the picture of where it failed.
taxx
Make em say Ugh
- June 11, 2001
- Indianapolis, IN
- 73 EB
I ran one in the 44 on my sploder for a couple years and I do believe whoever owns it now that its still in there and working even with chromo shafts. I just don't like it cause its not selectable. Makes tight turns hard.
taxx
Make em say Ugh
- June 11, 2001
- Indianapolis, IN
- 73 EB
Hmm im starting to think i got a dud. lol
Maybe maybe not. I have heard other people ***** about them too. They are no Detroit. Maybe I got lucky? What axle was yours in? I have heard more complaints from Jeepers so maybe the 30s and 35s versions aren't as good. I don't know. Just wanted to state it worked for me. I was told the same thing after I installed it and said oh well I will run it till it gives. I lost a t-case, many front shafts, but never the locker.
DB_1
Elite Ranger
- October 23, 2001
- La Quinta, Ca.
- 97 SC Ranger xlt
Felix used to have one in his D44 and had the same problems with the clicking noise. Froader has since bought his rig and put in a tru-trac now.
I thought i'd try out an Aussie Locker in my D44 which looks much like if not exactly like the other lunchbox lockers. I've been on 2 runs and so for it's been flawless, turning with a locker was a little wierd but it's not as bad as I thought it would be. Best $230 i've ever spent and they claim no tire size limit...we'll see.
Anyways back to the locker issue, I don't know about the other lunchbox lockers but the instructions witht the Aussie locker give you 2 tolerances to check, they say if either of these are not within spec then the case or thrust washers are likely worn and the locker will not funtion properly. I'd check the thrust washers to make sure they aren't warped by visually checking them on a flat surface.
If there are no tolerances given i'd call the mfg. and see if it necessary to be checked and remedied.
JoshC
- May 1, 2000
- Culloden, WV
- 97 4d OHV
Yeah i put it in and it all speced out good. I ran a lock rite in that D30 for a while and snaped 2 joints on 35's. I agree, best spent money IMO.
I've been trying to come up with an idea but i'm not really sure. If i go with the link setup in the pics on the last page, what do i do for coil spring seats?
IZwack
Moderator Emeritus
- February 5, 2003
- Germantown, MD
Make your own.. what do i do for coil spring seats?
redranger4.0
- April 8, 2003
- Salem CT
- 2000 Ranger XLT
ballistic Fabrication has some nice coil seats. I have them to put on my 44 they cost me like 20 dollar for the set.
on a side note, did the guy who did your original sas cut up the stock upper cherokee arms and weld them to tube?
redranger4.0
- April 8, 2003
- Salem CT
- 2000 Ranger XLT
JoshC
- May 1, 2000
- Culloden, WV
- 97 4d OHV
yep
taxx
Make em say Ugh
- June 11, 2001
- Indianapolis, IN
- 73 EB
JoshC
- May 1, 2000
- Culloden, WV
- 97 4d OHV
Well i went out in the shop tonigh in hopes of doing some work. All i got done was some measuring. I'm going to have to come up with something different for a coil seat for the axle because where the coils need to seat is right in the way of the C's. I'm not 100% sure what i'm going to do but i'm open to ideas. One i was thinking of is kind of like the D30. It's got a plate about 6 inches x 3 inches welded on top the axle. One the front side is the coil seat and the back side is the shock mount and on the bottom of the back side is part of the control arm mount. So any ideas?
Similar threads
- Replies
- 376
- Views
- 45,747
- Replies
- 43
- Views
- 28,276
- Replies
- 4
- Views
- 1,733
- Replies
- 542
- Views
- 87,981
- Replies
- 24
- Views
- 8,562
