LukeRust
- January 20, 2021
- Hermitage
- 1993 ford exploder sport
1993 Exploder sport 4x4 2door
The vehicle is a beater off road rig. Im just trying to get more ground clearance out of it for the trails.
Right now i have 2" coil spacers in the front and 2.5inch lift shackles on the rear and i clear 31" tires just fine. My leaf springs are bad so im going to replace them with sport trac leaf packs which are a 3.25" lift. Now i need to even it out in the front and get shocks that fit. I can either get coil springs that are 3-4" taller than stock and still use my 2" coil spacers or i can get coil springs that are 5-6" taller than stock and ditch the coil spring spacers. Ditching the coil spacers is the better option if possible because it will help increase travel.
What vehicle could i rob these parts off of at pull-a-part?
