Riceburner247
- April 30, 2006
- '92 EB
If you're running big tires with offset, you should check your D35 wheel bearings before you go out to play. I did and my wheel was wobbling. Pulled wheel/hub off to tighten up the locking nut and realized it was completely tight/didn't want to tighten any further. My rotor still wobbled though? Pulled EVERYTHING off and found this, lmao.
The inner bearing had, for lack of a better term, "disappeared". So..... yeah. It only takes a sec to do and you'll feel better knowing you did.
I can't wait to start my SAS.
