just a thought | Ford Explorer - Ford Ranger Forums - Serious Explorations
just a thought
Fordmandan87
Royston, G.A.
in process of purchase
for all of u guys that are putting money into the whole solid axle swap thing i was wondering if you could theoreticly put a solid jeep cherokee front axle on the front. to my knowlagethe track widths are close enough. i was also thinkin that with the front axle being a full time axle the whole thing with going outside to lock the manual hubs in order to attain 4wd would be eliminated. also seing as the two axles are dana 35' you could swap your gears from axle to axle without a problem. and finally the bolt pattern is the same on both axles so no new wheels would be necessary please leave me feed back
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
yes, you can do it, it has already been done. Widths are close, BP are the same, gears wont interchange, and the full time 4wd system with vacuum disconnect wont work with your explorer without a bit of work as far as I know. Plus real men get out and lock their hubs, its not a problem.
And its a fairly weak axle, IMO its dumb to use a d30, just get a 44.
Fordmandan87
Royston, G.A.
i am not saying getting out to lock the hubs is a bad thing i personally dont mind it but it gets harder to do so when ur in bumper high whatever
Fordmandan87
Royston, G.A.
how much wider is the grand cherokee?
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
probably the same, maybe an inch or so difference.
Fordmandan87
Royston, G.A.
then again this idea is for those who cant afford to go balls to the wall with a fullsize axle swap. is there anybody with pic of a cherokee axle on an explorer?
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
search
Dana 30 and dana 35's have been done btoh with leafs, coils and long arm Jeep kits
James Marcy recently posted a thread on here where he and his son put a dana 30 under a BII using leaf springs, great article
The problem with putting a Jeep axle under a Gen I explorer is this:
a early bronco solid axle will almost BOLT IN to your truck, keeping the steering box, coil buckets, shock mounts, etc The EB axle can be done over a weekend easily
HVAC man had a dana 30 under the front of his Explorer sport with coils for a bit
There are others
Search around a bit
Fordmandan87
Royston, G.A.
thnx 410
sn0border88
Master Apprentice
Souderton, PA
1992 XLT
the axle you use wont really make a difference in price, its what you decide to put into the swap.
