Robert7x
- July 26, 2015
- Clayton
- 2004 explorer
Hey guys, just recently I bought a 2004 Eddie Bauer Explorer, V8 with 150K miles on it. It seemed like in a good condition without any issues.
I did normal stuff, engine oil change, filter, air filter, pcv etc. Brakes, Upper Ball joints and sway bar links this weekend.
I was reading a lot on these forums about transmission oil and changing it... I'm really not sure what to do about it at this point. I don't know if it has ever been changed or not. Carfax lists some maintenance done, but not sure which.
To make matters worse, after having it for about a week, I drove 250 miles total, maybe... This morning on the way to work, once I got on the highway, O/D light started flashing and it said check transmission. I started reading all the threads on the forum and it could be number of issues from Bad transmission, to bad solenoid pack, fluid old, etc etc.
So that brings me to this question... should I attempt to change fluid and filter and see if it helps, or maybe it's something else? Another thread mentioned that the brake switch could be causing it? The OD seems to engage though... It shifts fine everywhere else... no loud thumping when changing gears... goes from R to D just fine.
Anyway, that's my main worry right now. Overall, all the other things are just maintenance.
Thanks a lot gents.
Thanks a lot gents.
