Hi its CedTheProwler
I have a 2015 ford fpiu 3.7L
bought @ roughly 68,000miles now @ 78,289
Man I've been gunning this issue down for a few weeks ughh.....
This symptom replicates a faulty MAF , throttle body , coils, plug you know where I'm going
I noticed the issue start to get worse about 1 week ago > current 11/10/21. and when the temp reaches it highest point .like driving in city or HWY
I'll tell you what I've done so far Changed spark plug, cleaned MAF and Throttle body , changed EVAP purge valve,
and also pvc valve.
none of that worked......
Mind you now after doing all this , one day it hit me maybe the transmission needs maintenance!!!
This morning i went to ford @7:30 am to grab merconLV 5 quarts tranny fluid and a radiator cap only cause i need a new one but besides that i did the fluid change myself .
took out the plug for transmission using a 11mm and let drain fluid was mad dark. its a really easy job guys and i believe it solved the problem
it gave me amazing results what i was looking for .... stops the shuddering under low acceleration
(Keep in mind) I only did a fluid change not a FLUSH
after fluid change i did noticed a light shudder sometimes but it wayyyy better than before so that lets me know that the old fluid lost its working properties.
LOL its barley noticeable tho now when its does occurs its like car is being tickled just a bit
but man fluid change is defiantly required don't hesitate guys to change it !!
I know you guys mentioned you did a flush but i wanted to save money $$$ and probably do another fluid change in about 1,500 miles to get the remainder of the older fluid out of there
