shadowless127
- December 13, 2007
- Long Island, NY
- '01 EB AWD 5.0
Just changed my front brakes. When doing my drivers side brakes, for some dumb reason I had a brain fart and accidently loosened the bolt that I assume attached the hose to the calliper, because fluid started coming out. So I tightened it up, but apparently not well since when i did a test run after the brake job I had NO stopping power. Get home, spot the leak, get under and tighten up the bolt more; had a friend of my press the pedal a few times and no leak. Took the trusty 'ole 93 X to the store to get some more brake fluid, topped of the master cylinder and now I have SOME stopping power but not nearly enough where I feel comfortable driving it to work tuesday.
I'm gussing I got a massive amount of air in the lines. Hoping someone is open tomorrow because I REALLY don't want to take the 93 to work lol.
Is my assumption correct?
