Just got 2016 explorer xlt with 20s, I have a question.
Rocco1005
Oklahoma city
2016 xlt
Right now my tires are 255/50/20, is it ok to go to a 265 width tire? Never had an explorer so just making sure everything would be fine . Thanks
Mike65
Location
In my garage working on one of our vehicles.
Toms River, NJ / Horsepasture, Virginia.
00 Ranger 4x4, 99 Sport.
Welcome to the forum Rocco1005. You should be able to go to a different size tire, but it will change the reading of your speedometer, & it might have an effect on your gas mileage. I do not know if it will change anything else.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum Rocco. :wave:
A 265/50R20 will only have a nominal 1% difference in diameter variance. When the speedo reads 60 mph you will actually be going 60.8.
Watch those radars.:)
Rocco1005
Oklahoma city
2016 xlt
Ok thanks, what about rubbing?
Adrian Gitch
Paris, KY
2015 Explorer Limited
If you're just changing the width (255 to 265) then no change on speedo and you're only going about 3/8inch wider so you shouldn't have any issues
peterk9
Staff member
Moderator
Callsign
VE3
0.8 mph change in speedo as stated. 😊
Michael Lopour
Scottsdale AZ
Expedition Limited 302A
I think Peterk9 is right; while 255 to 265 seems like you’re only changing width, 50 represents a ratio of height to width (or vice versa) so the new tire will have a larger diameter than the old one.
Adrian Gitch
Paris, KY
Crap I forgot to account for that. I wonder if that small of change would be even noticeable on the speedo. For me it maybe would since I'm ocd
Michael Lopour
Scottsdale AZ
Will the size change save you money? Just wondering if it’s worth the trouble. I use the engineering mode to calibrate the MPG meter but I’m not sure if you can calibrate speedometer that way.
peterk9
Staff member
Moderator
Callsign
VE3
I would think that it would likely result in slightly lower MPG since you are now pushing a wider tire and will likely add a bit more 'rolling resistance. A wider tire would also be more prone to hydroplaning and harder to push through snow. Personally, I'd stick with the OEM size.
Michael Lopour
Scottsdale AZ
100% agree but I was focused solely on purchase price.
peterk9
Staff member
Moderator
Callsign
VE3
I checked the sizes on several tire brands and the differences vary somewhat. On some the 265 is slightly more expensive while on others they are slightly less expensive. So whether it will save you money to go with the 265 depends entirely upon which brand you choose.
