  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
Just heat
Doug 66
hudson ill.
2002 explorer
I have an 02 explorer and all I get is heat out of the vents . Ive opened the glove box door and saw the actuaters working and moving the blend door ,so I have no idea what the problem is.
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Do you here any clicking behind the dash when you change the Temp Control Knob?
Do you have manual or automatic climate control?
Doug 66
hudson ill.
2002 explorer
I have manual controls with no clicking behind the temp control knob. I do have the clicking in the back of the truck though
Exproblems
Orchard Park, N.Y.
'05 Explorer XLT 4.0L
Do you have "rear heat" along with temp controls for the rear seats? If you do, you could have a bad"rear blend door actuator" for the rear heat, even though the front blend door actuator is working fine. The clicking noise you hear is usually from a bad blend door actuator. There are past posts in here on how to replace the rear blend door actuator as well as the front one. Just use the search box at the top of the forum and type a question related to that issue into the box and include your year Explorer and engine size into the question. The system will pull up past posts according to what you type into your question.
J 03 Explorer stuck on heat Stock 2002 - 2005 Explorers 2
P No rear heat Stock 2002 - 2005 Explorers 1
A Rear Heat Stock 2002 - 2005 Explorers 1
T 2004 explorer rear heat and air Stock 2002 - 2005 Explorers 1
J Tricky Front End Heat Question Stock 2002 - 2005 Explorers 6
A 02 explorer 4.0 No Rear Air/Heat Stock 2002 - 2005 Explorers 0
I Still no heat Stock 2002 - 2005 Explorers 1
D 2005 Ford Explorer Ltd heat/ac issues-vacuum leak or blend door ? Stock 2002 - 2005 Explorers 0
M 2004 Explorer no heat Stock 2002 - 2005 Explorers 4
S 02 EB Dual Climate ZERO heat Stock 2002 - 2005 Explorers 9
H Heat works but won’t blow hot through defrost Stock 2002 - 2005 Explorers 6
K Not much heat Stock 2002 - 2005 Explorers 26
E 2002 Ford Explorer XLS heat not working. (Video attached) Stock 2002 - 2005 Explorers 1
0 Clicking Sound When Using the Heat. Stock 2002 - 2005 Explorers 1
J 05 explorer no heat Stock 2002 - 2005 Explorers 32
G Defrost/heat issue Stock 2002 - 2005 Explorers 0
R HELP! It's getting cold, I need more heat! Heater issues! Stock 2002 - 2005 Explorers 2
R Heat shield question Stock 2002 - 2005 Explorers 2
M 2003 Explorer not blowing heat Stock 2002 - 2005 Explorers 3
F Missing piece of plastic duct for 2nd row heat and ac? Stock 2002 - 2005 Explorers 1
H Only the heat works when air is on high? Odd pop noise? Stock 2002 - 2005 Explorers 1
P AC and Heat Stock 2002 - 2005 Explorers 1
M '02 4.6 No Heat Stock 2002 - 2005 Explorers 20
S No Heat Problem! Anyone had this? Stock 2002 - 2005 Explorers 5
D 05 Ford Explorer XLT v6 4.0L weak AC/heat and loud noise when on hi Stock 2002 - 2005 Explorers 1
L Heat and AC not blowing right Stock 2002 - 2005 Explorers 6
S 02 EB Explorer w/ DATC *NO* heat at all Stock 2002 - 2005 Explorers 5
M Heat gets warmer on acceleration, cooler at idle Stock 2002 - 2005 Explorers 11
M Weak blowing Heat/AC Stock 2002 - 2005 Explorers 8
R Heat only blows while moving or once car is 100% warm Stock 2002 - 2005 Explorers 4
T Changed stereo, now no heat??? Stock 2002 - 2005 Explorers 3
H Heat only works in high? Thump noise? Stock 2002 - 2005 Explorers 5
C Low heat output Stock 2002 - 2005 Explorers 1
W Weak A/C and Heat Stock 2002 - 2005 Explorers 1
F stumped. rare random heat for short periods of time Stock 2002 - 2005 Explorers 0
L AC/Heat vacuum leak? Stock 2002 - 2005 Explorers 4
G Dual passenger heat have 2 blend doors? Stock 2002 - 2005 Explorers 4
N Heat blows cold air when stopped Stock 2002 - 2005 Explorers 24
J No heat when stationary at idle Stock 2002 - 2005 Explorers 3
T 2003 Mercury Mountaineer AWD v8 heat issues Stock 2002 - 2005 Explorers 7
J 2002 Explorer heat control valve Stock 2002 - 2005 Explorers 1
G Heater clicking; no heat 2005 Stock 2002 - 2005 Explorers 0
M Poor Heat from 2004 Explorer, and howling noise Stock 2002 - 2005 Explorers 1
E AC barely and no heat. Stock 2002 - 2005 Explorers 1
G 2002 ac/heat/vent problem Stock 2002 - 2005 Explorers 6
I Heat all the time Stock 2002 - 2005 Explorers 3
J Heat/Air Directional Issue Stock 2002 - 2005 Explorers 1
C Bad gas mileage and no heat at an idle, HELP!!!! Stock 2002 - 2005 Explorers 2
L Another "no heat" problem Stock 2002 - 2005 Explorers 4
J lack of heat Stock 2002 - 2005 Explorers 6
Similar threads
