- February 8, 1999
- 2006 Honda Accord
Originally posted by leebo
Should I go up to 10feet from the truck for backing up or should I aim them farther out for use on the trail(hooking up the strap and so forth) and let the reverse lights on the truck light up the area for backing up. What do you guys think????
Well Lee, I would set them up for backing up my self, because you will be backing up alot more times than using them to see what you are doing when strapping up. If you absolutely need to use it for that, then adjust it when need be.
