JC3006
- May 14, 2020
- Kentucky
- 1991 Explorer Sport
Hi guys,
I lurk around here a lot more than I post, but I just wanted to share some of my latest projects. When I tore down, it was for quickly patching some rocker panel rust and rear brake job. I never intended to delve this deep, but sometimes the OCD bug takes over. This Explorer has went from daily driver, to yard ornament with a blown engine, to running back-up vehicle, to quasi-restoration project. I’ve had an absolute blast rebuilding this thing, it’s been very gratifying. Just wanted to share, hope y’all enjoy.
3 years ago, shortly after bringing it back from the grave. Rebuilt engine, serviced trans, F150 coil spacers, new tires. Runs good, repaired the A/C, got all the door locks/windows working for the first time in like 15 years. Ride is mushy/sloppy, A4LD is questionable.
Tows really well. A4LD actually improved a lot after this trip… maybe it got hot and loosened up some of the old varnish and gunk. Brakes were freshly rebuilt but need some serious help, the peddle is mushy and pulses, wheel bearings are noisy.
Hit a deer with my daily driver last winter, so the X pulled snow duty while the Nissan gets repaired. Handled the weather great, but the electric BW1354 had some trouble when the temps got close to 0. Also, something growls a lot in the front, either Ujoints or Spindle bearings? Also developing a clunk under hard braking. Rocker panels were starting to dissolve. Told myself that once I got my Nissan back from the body shop, the explorer was gonna get some love.
Rockers were worse than I thought. Had to fab inners out of flat plate and source the middle rockers from a junkyard. Outer skins came from EBay, company called “motorcity sheet metal”, and they fit really well. Everything was weld-thru primered, seam-sealed and undercoated. This repair should last longer than I do.
I didn’t get many pics of the process, but since the rear axle was out for rust repair, thought it’d be a good time to address the rear brakes. Rear ended came from a low mile ‘95 explorer. Cleaned, resealed, POR15’d. Undercarriage and frame was cleaned and POR15’d as well. New Flowmaster Super 44 and hi-flow cat (exhaust smells SO much cleaner now). Rebuilt the driveshaft. Finished up the bodywork and used DupliColor bed liner up past the side molding. I still need to finish up the Ebrake cables,
I wanted to stop here… but remember how I mentioned the OCD thing?
Front end got completely stripped down and given the same treatment. Frame was cleaned and POR15’d, TTB bushings replaced, new Radius arm bushings, diff removed and resealed, axle shafts rebuilt.
Heads up for anyone working with POR15: the base coat sprays beautifully, but the top-coat runs very easily (it was cold here when I sprayed, so maybe that’s why?). KYB shocks, Skyjacker 2 inch coils.
New rotors, pads, SKF wheel bearings and seals, Spicer Ujoints. Done and done.
Needs a wash and a wax, it has sat while I spent all summer/fall underneath. I’m very happy with how it has turned out. Still need to repaint and install the flares, and I suspect it will need an alignment. Next up is window tint and a sound system. Notice the M5OD in the background?
Also, finally scored a complete BW1354 manual setup (including a double shift boot/bezel), So that will probably take place soon.
So that’s where we’re at for now. Hope to have some more pictures and updates soon.
