K & N air filter install help
Mustangmars
Lake Orion MI
2018 Explorer XLT
I recently purchased a K & N air filter for my 2020 XLT 2.3L. My problem is, i cannot open the air box and the instructions in the owners manual do not seem to help me. The instructions show to loosen two clips and remove 2 screws on the air box. The clips are no problem, however, i cannot locate them two screws referenced in the manual. Does anyone have any experience with changing the air filter on your 2.3L? Thank you!!
Join the Elite Explorers for $20. Gets rid of the ads!
Dsle5403
Mondovi, WI
2020 Explorer ST
I haven't changed the filter but the screws referenced in the manual are for the clamps on the 2 air hoses.
After removing the hoses you should be able to remove the cover.
Mustangmars
Lake Orion MI
2018 Explorer XLT
Thank you Dale! I will give it a try.
northvibe
2020 Ford Explorer XLT
Were you able to remove it? Sometimes those hoses are super stiff so they need to be loosened or removed to get the box top off
joshua Evans
Location
minneapolis
Minneapolis Minnesota
2020 explorer ST
I replaced mine with an AEM filter.
Just remove the hose clamps that hold on the hoses running to the box and slide them off away from the box. Then unclip the 2 latches take the air box top off replace filter and put it all back together. 10-15 mins tops
Mustangmars
Lake Orion MI
2018 Explorer XLT
Thank you again guys! I have not had time to try again yet. Hopefully tomorrow! I will reply with my experience one i give it a shot.
joshua Evans
Location
minneapolis
2020 explorer ST
By hoses I meant intake tubes
Mikey*TX
Location
Liv'n in the hollow of an 'ol oak tree. ;-)
Skunk Hollow, TX
2020 EXP ST Blk
This ! Not even a one beer job ............. Bummed ........ :snicker:
Mustangmars
Lake Orion MI
2018 Explorer XLT
I finally had time to use everyone’s advice! Once i pulled the tube by loosing the clamp, it was simple, under 5 minutes. Thank you!!!
