K&N Drop in filter. Does it make turbo's louder
MGlunt109
Bellefonte, Pa
2016 Explorer Sport
Hey Guys! I recently just got rid of my 2015 wrx. The only thing I did to that car was put in a KN air filter in it. It obviously didn't add any HP and I could careless about gas mileage, but what I did love was the fact that the Turbo spool was a lot louder. Has anyone put one of these in a 3.5 ecoboost exploer? Does it sound better? are you happy with it?
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
03WIExplorerLtd
2011 Explorer FWD base
Probably not much, had them in multiple cars haven't noticed much. Gas mileage probably goes down, I keep trying to see if its louder...
jonnoriega
Location
Northern IL
Streamwood, IL
2016 Ford Exp Platinum
had it in my '16 platinum. sounded a tad bit louder but not by much. recently installed ecopowerparts hot-pipes, tranverse CAI and Tial BOV. now it sounds louder!
here's the hot-pipes and bov with my original CAI from @Livernois
Pmtroutok
2015 Ford Explorer Sport
How does your turbos spool when your not in gear and under load? I tried reviving mine and it’s just like non turbo lol
peterk9
Staff member
Moderator
Callsign
VE3
^^ Welcome to the Forum.:wave:
jonnoriega
Location
Northern IL
Streamwood, IL
No but you’d expect to have some turbo noise revving it up should I? Jut making sure I’m not having any problems
With OEM, you're not going to really have any noticeable noise coming from the turbo's sadly.
DUK010
Fenton, Michigan
2015 Explorer Sport
Nice Jon, your setup is top notch! Sounds tough!
Kyle Baker
Minneapolis, MN
2016 Explorer Sport
@jonnoriega , when are you going to put the raptor style grill on that beast?
BigJuan
des plaines
2018 Platinum
New here but not new to Explorers. We are on our second 5th Gen. Our first was a 2014 that we put nearly 180K on before it wasn't worth repairing anymore. We currently have a 2018 Platinum with a tad over 120K miles on it. While we're not necessarily hard on cars we do put a ton of miles them every year traveling between businesses around the country. Started poking around here and decided to give my experience with the whole aftermarket filter thing. With the number of miles we put on each year it's cost effective to buy the K&N. For the current car we have two of them and just swap it out every 30K miles or so and clean the old one when time permits. Keep in mind that the truck is 100% stock other than Power stop Brakes and the filter.
The questions always comes up.
- Is it faster, does it make more power? More power, Maybe a couple but not enough to notice so NO it's not faster.
- Is it louder? Yes. but not enough to notice if you are driving down an open road. If you are in a tunnel or parking garage you can hear the turbos spool and it is louder.
- Is the gas mileage better. We'll that depends on you. If you drive it harder wanting to hear the noise then the mileage drops. Out on the highway, I'm averaging right at 21.8 mpg at 80ish mph with the cruise on. Don't know how that compares to others but we track our mileage and fill ups for business expense purposes, so I have the data.
The other question that people ask is, aren't you concerned that it will hurt the motor because more dirt gets in?? Quick answer is, No i'm not. The rest of the car will fall apart around the motor before you see any negative effects from any change in filtration.
Now I don't have any scientific data to support this, but I can share my experiences. The 2014 Explorer was NA and we ran full synthetic oil in it after the first oil change. Due to mileage and the fact that the car lived on the highway we changed the oil every 10K miles and cleaned the filter every 30K or so. When we finally sold the car at 180K miles the engine had no internal issues that would be related to filtration. By that point most of the accessories on the motor had failed, the suspension had been almost entirly replaced, steering replaced, transmission replaced, bearings, axles etc. and lets not talk about the electrical issues but nothing internal on the engine so I don't feel the filter had any detrimental effect on the engine.
Fast forward to the 2018. With the turbos I'm a bit more cautious with the oil changes and typically do them between 5K-6K miles. For us that comes out to an oil change about every 6 weeks or so. The K&N filter get swapped out for a clean one around 30K or so. To date I’ve not had any internal engine related issues. Everything around it is failing but the motor internally is strong.
While we love the comfort and performance of the 2018 it is unfortunate that we are seeing the same issues we had with the 2014. Most alarmingly is the transmission and suspension issues. The transmission failed at right at the one year mark at 60K miles and is beginning to show the same signs again. Looking to keep this one to the end of the year or around 150K as we're thinking of moving up the 2021 but i'm not putting another transmission in it.
peterk9
Staff member
Moderator
Callsign
VE3
Welcome to the Forum Juan. :wave:
That is a whole lot of miles for a 2018. At my current annual mileage rate, it would take me 48 years to accumulate that much.:laugh:
BigJuan
des plaines
2018 Platinum
Yeah we put a lot of miles on every year. My GF's family owns businesses around the country that she manages so we're on the road pretty much all the time. Can be in Chicago on Monday, Tulsa Tuesday, somewhere in Texas on Weds/Thurs.
We need a car when we get where we're going so it doesn't make sense to fly and rent all the time. Sometimes she flies and I drive down the next day.
Odrapnew
MN
2014 Explorer Sport
The only way to know for sure of the filter is letting in more dirt and possibly causing more damage is to get the oil analyzed. While the K&N has been proven to have lower filtering efficiency, as you stated, something else will likely go bad before the engine dies due to filter efficiency.
ecoboost_xsport
Mad Scientist
Orangevale, California
Not sure about drop in filter, and this may not do you any good, but here's a sound clip of mine just idling. But I do have quite a few extra mods, LOL. That sound of the sucking in is pretty significant. I also have the Tial BOV, but changed from their full vent to the directional one, simply for the BOV sound...does nothing for power or serve any purpose other than that, LOL.
K Which drop in air filter is best for the Explorer Modified 2011- 2019 Explorers - Tuning & Mods 38
1 Oracle 9005 LED Drop In Kits Modified 2011- 2019 Explorers - Tuning & Mods 1
M aFe Pro Dry S Filter - 3.5L NA Modified 2011- 2019 Explorers - Tuning & Mods 8
X Time to change engine air filter Modified 2011- 2019 Explorers - Tuning & Mods 11
R Washable air filter? Modified 2011- 2019 Explorers - Tuning & Mods 1
A Where does everyone get their custom OVAL emblems? Modified 2011- 2019 Explorers - Tuning & Mods 3
U Does the 2.3 Ecoboost have an intake silencer? Modified 2011- 2019 Explorers - Tuning & Mods 5
1 Does anyone want to sell me their stock resonator? Modified 2011- 2019 Explorers - Tuning & Mods 0
G Does Anyone Else Hate The Amber Headlight Housings? Modified 2011- 2019 Explorers - Tuning & Mods 1
T Does a tune get your rev matching? Modified 2011- 2019 Explorers - Tuning & Mods 19
W Does anyone have Any Pics of A/T tires on 20 or 22 wheels? Modified 2011- 2019 Explorers - Tuning & Mods 17
J Does F150 use same BOV as Explorer? Modified 2011- 2019 Explorers - Tuning & Mods 4
A does it worth to change the Thermostat & Spark-plugs for the livernois tuning device? Modified 2011- 2019 Explorers - Tuning & Mods 4
B Does anybody know is smoke tinting the headlights is NOT LEGAL in Canada?? Modified 2011- 2019 Explorers - Tuning & Mods 2
E Ford Explorer Chrome Rear Bumper Guard: What does it look like? Modified 2011- 2019 Explorers - Tuning & Mods 0
E Does it help to swap the standard halogen headlights for aftermarket brands? Modified 2011- 2019 Explorers - Tuning & Mods 11
Similar threads
