Kaczman's Sport Trac Finished Thread | Page 3 | Ford Explorer - Ford Ranger Forums - Serious Explorations
OffTrac
Dublin, GA
'01 Sport Trac 4x4
No spacers needed. I actually have 4.25" backspacing. Get 4" if you can but a 1/4" in either direction will be ok.
kaczman
ohio
2002 Heavily Modified ST
Ok. So if I get 17x9 wheels with a ~3.75-4.25 backspacing, I can fit 35x12.5x17 tires on them, and need NO spacers front or rear, correct?
OffTrac
Dublin, GA
'01 Sport Trac 4x4
That will work. I don't about the offset but my 17x8 with 4.25" backspacing has -6 offset. The same wheel in 17x9 and same backspacing has -19 offset. Hope that helps.
Govna47
Oak Ridge, NJ
01 Sport
I like
kaczman
ohio
Man, I've had a hell of a time finding wheels that will work.
So far, I've found:
Ultra Crusher 17x9, with a 4.5" backspacing (too much?)
Ultra Rogue 17x10, with 4.5" backspacing (too much?)
I dont think either of those will work without spacers, so I also can use any of these,
http://www.ebay.com/sch/Wheels-/439...5&_ssov=1&_trksid=p3286.c0.m1583&Offset=%2D12
All those wheels are 17x8.5 with a 4.25" backspacing, which should fit 35x12.5x17 tires with no spacers, front and rear, correct?
Any ideas?
kaczman
ohio
Offtrac, can I get a few more pictures of your truck with the 35"s? I want to see how far the tire sticks out of the wheel well with no spacer if I go with that same backspacing and rim and tire size.
Also, do you have any MT sound INSIDE the cabin with the windows up?
OffTrac
Dublin, GA
'01 Sport Trac 4x4
Here's the best picture I have of how far they stick out. I'll try to get some more later. Keep in mind that I do have a 1.5" spacer on the rear.
There is definitely more cabin noise than my all terrains had, but it's not that loud. It completely drowns out with the radio at only about 1/4 of the way up. Now, with the rear window down, there's definitely a howl.
kaczman
ohio
That looks perfect. Will I need a spacer on the rear as well? I dont get how it looks even without one on the front.
OffTrac
Dublin, GA
'01 Sport Trac 4x4
You don't need a spacer. I just wanted to cut less plastic and push the wheels out more even with the front. Look closely at yours. The front hubs are further out than the rear. The rear tires tuck in a good bit in the rear.
kaczman
ohio
Thanks Kaz!
And offtrac, if I DONT use a spacer, will the wheels still match up evenly front and rear in terms of being even with the space from the wheel wells?
essendon22
Tampa, FL
2005 Adrenalin 4x4
Good luck man, that whole BS and Offset biz was really stressful when I was looking. Gotta say I really like the all black look, and those headlights look sick with it all. Love the radio too, I want to get something like that.
OffTrac
Dublin, GA
'01 Sport Trac 4x4
Thanks Kaz!
On a 12.5" tire, it'd probably be pretty close in terms of the wheel wells. Lucky for you, you already have spacers. Just mount them without and if you think they need a little bump out on the rear, put them on and see what the difference is.
