key fob issues | Ford Explorer Forums
key fob issues
07gtman
Chicago IL
2005 Mountaineer 4.6 AWD
i have an 05 mountaineer the key fob works when it wants to mostly when its warm outside or if its very hot inside the cabin of the truck in the winter..Ok i have 2 cheep remotes and 2 originals all new batteries in them and they all work.Reprogramed them but can only do a reprogram when the remotes work.Same results in the winter i can take the key out of the ignition and wait 20 seconds and fob stops working.i have found 4 broken wires in the door and did the repairs to them puddle lights door ajar wd40 lol now its winter again and my door key pad is wearing out i am at a loss need to keep the car locked living in Chicago lol...hope someone here can help....thanks
i have an 05 mountaineer the key fob works when it wants to mostly when its warm outside or if its very hot inside the cabin of the truck in the winter..Ok i have 2 cheep remots and 2 originals all new batteries in them and they all work.Reprogramed them but can only do a reprogram when the remotes work.Same results in the winter i can take the key out of the ignition and wait 20 seconds and fob stops working.i have found 4 broken wires in the door and did the repairs to them puddle lights door ajar wd40 lol now its winter again and my key pad is wearing out i am at a loss need to keep the car locked living in Chicago lol...hope someone hear can help....thanks
update ....Went outside this morning hit the key fob nothing (i knew that would happen)so i pulled the passenger rear kicker panel away far enough to get at that dreaded black box .Took my heat gun and put some heat on it 15 seconds or so hit the button and boom open they worked ...i get a small fan put it on that black box wait 15 minutes go outside hit the button nothing ...Ok the gloves are off now...Go to the garage and get me 5/16 socket and pull the box out.Go to the basement heat gun in hand grab a screw driver and pry open the box to expose the circuit board lay it on the work bench and put the heat on it...moving the heat gun as to not cook any one spot but evenly heat the whole board got it nice and hot .With gloves on picked up the board and put it outside.(its about 30 degrees out) let it sit about 30 minutes.Now nice and cool plugged in the circuit board to test it hit the fob and boom doors unlocked i put the fan on and wait another 30 minutes(still not convinced) go back outside hit the fob and it is in fact working> put it back in the black box reinstalled it.put everything back together trying the button from time to time everything is ok.Take it out for a drive hitting the bumpiest road i can find just in case.....got home hit the fob and it worked..i think its fixed in the time i have been writing this i have been randomly hitting the button to hear the horn chirp ...one last thing..the fob now works from a very long distance my driveway is 85 feet and it works from the end of the drive never did it from that far before.Dont know if this will help anyone but thought i would put it out there anyway
