Key FOB won't unlock doors | Ford Explorer - Ford Ranger Forums - Serious Explorations
Jeff352
West Jordan, Utah
2000 XLT
I have a 2000 XLT that won't let me unlock the car using the key fob. I can lock it though. I tried reprogramming, but it did not change the status of the fob. It has the same problem with both my fob's. The keypad works fine. Anybody have any ideas?
Cranmaro99
2001 Explorer 5.0 AWD
I have the exact issue as you. Two FOB's, both unlock buttons don't work, but everything else on the FOBs and car work fine.
I'm sure it's just the buttons are worn out considering the other ones work fine.
1996BLKBauer
McHenry, IL
1996 Eddie Bauer AWD V8
Cranmaro99
Awesome, thanks for the video and that is good to know for future knowledge. I would have never have figured that one out on my own, lol.
However, my unlock buttons on my key FOB DO in fact work, but only if I really press hard on the button. So to me it seems like the buttons are just worn out. If it was the bad wire under the passenger rear door I don't think it would work based on how hard I push the key FOB button.
It's just weird that it's both unlock buttons only on both of my key FOBs. We shall see.
budwich
Ottawa, Ont
96 XL
agreed... its unlikely to be a wiring problem since your door key pad works which I think uses the same "wiring" (basically). The remotes are just like any other remote (ie TV etc)... the contacts under the pads get "gummed up" from "finger juice" and eventually failure to work reliably... cleaning will likely improve its operation. As to why... probably you use the unlock more often than the other plus... your fingers are touching things when you come back to the truck and may have a "bit more contamination" then. :)
Jeff352
West Jordan, Utah
2000 XLT
Is it going to be the same wires if my explorer has the opposite problem? I can lock, but not unlock the doors which is the recipricle. I would agree with corrosion on the fob contacts except one of my fobs is never used and I checked the contacts on the fobs and there is no corrosion or oxidation. I cleaned them anyway. Still will not unlock the door.
1996BLKBauer
McHenry, IL
It may, I know there is a thread on here about it, with different problems, with not locking, or not unlocking, so it may be. Look up in the search thing "door lock splice" or something like that, you should find the thread,
Edit, I found it for you...
http://www.explorerforum.com/forums/showthread.php?t=179629&highlight=door+lock+splice
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Do the doors unlock from the door switches, but just not the fob? There is a separate connection from the RAP module (what the fob talks to) to the unlock relay that may be the issue.
budwich
Ottawa, Ont
96 XL
IF your door keypad works and fobs don't then you have a "fob problem" since I think the "system" is the same most of the way.
Of course, IF you don't have a keypad to test against, then its likely that you have the "rotted splice" problem which people have indicated.... assuming that buttons around the vehicle work accordingly.
Jeff352
West Jordan, Utah
2000 XLT
Key FOB only works half way
Keypad works. Key FOB locks. Everything is working but unlocking with the FOB.
Badmotorfinger
FL
2000 xlt 5.0 2wd
Had exact same problem, ordered new fob for $13, problem solved.
Jeff352
West Jordan, Utah
2000 XLT
Bought a new FOB, programmed it and it worked! Must of had some corrosion in the FOB contact switches on my old ones. It cost me less than $10.
Soulpol
Ann Arbor, MI
2000 XLT
Kind of same issue.
2000 awd 5.0 explorer and my fob will only lock and unlock the driver door. Tried resetting and new battery. Even disconnected the truck battery. Any suggestions? Will check for that corroded wire next.
bobflood
Powder Springs, GA
As far as unlocking with the fob goes, it's designed so one press unlocks only driver's door; second press should unlock rest of doors. There is a separate "unlock" relay for the driver's door to make this happen. However, all doors should lock with one press of fob.
Do all doors unlock correctly from door switches/door keyholes/keypad??
Soulpol
Ann Arbor, MI
2000 XLT
Yea the driver door will unlock with one press and on the second the rest of the doors wont unlock. I reconnected the pink and yellow wires and nothing changed even though they were correded. Sry so long for reply. Life happens. Haha. Thanks for the input though.
