NWExplorer97
- September 7, 2011
- Pacific NW, WA
- 97 Explorer XLT
I've gone through dozens of posts, so I'm finally putting it out to all for help.
97 Explorer XLT, 4.0L OHV, Auto, 4x4 in very good condition.
Recently started noticing battery issues, finally brand new battery went dead with no use in 2 days.
I checked alternator (1 year old with overdrive pulley) it's good at 13.65volts.
So then I checked for a key off draw, found it to be 3.97 Amps, obviously way to high.
Put Fluke Amp Guage between + post & cable clamp to measure. I let everything time out for about 1 hour. Then removed every fuse (interior & exterior) OEM & from all added accessories with no change. Then every relay in distribution block under hood and above gas pedal with no change. Then disconnected PCM, Alternator, Starter Relay, Coil Pack, etc. under hood with no change. I've disconnected glove box light, radios (3), off road lights, etc.
Also I can't see anything on or hear anything running like a pump or motor.
What else could it be? Any Ford Tech's that have seen this before?
I'm a retired 20 year ASE & Chrysler Certified Tech, I'm much more experienced with Chrysler electrical engineering. It's much simpler back in the 90's they used less relays and didn't share so many circuits.
I also volunteer with the local sheriff search & rescue 4x4 unit.
I have done TT, AAL-F150 rear springs, 1.5" spacers, 31" DuraTrac's, with these mod's it performs as well as any others on the forest roads, no hard off road wheeling. I like the Explorer and would choose it over a Jeep for various reasons. But I have to be able to depend on it in the worst conditions.
