keyless entry code? | Ford Explorer - Ford Ranger Forums - Serious Explorations
keyless entry code?
FordLover
Houston, Tx
'02 XLT
Any idea where to find the door code? looked around some, no idea where to find it.
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
drfrezer
Farmingdale, NY
2002 Mercury Mountaineer
It might be in the owner manual or you have to go to the dealer and they have to plug in to your car to get it out. The older fords had a tag but I dont think there doing that any more.
FordLover
Houston, Tx
'02 XLT
the first link brought up this
error 500: Interner Serverfehler
Das angegebene Skript konnte nicht fehlerfrei ausgeführt werden!
Thanks for the info, guess I'll have hit up the dealer.
MonumentalX
Grand Junction, Colorado
2003 XLT NBX
Sorry the link didn't work. I didn't have time to check it. However I just searched again and had many pages when I looked for 'keyless entry code' one was for a 3rd gen like yours. Try it and pick a link. Seems like it might be on the passenger door panel.
FordLover
Houston, Tx
'02 XLT
Turns out it's 'in' the computer only. have to get it read by the dealer.
Ray Lobato
Moderator
Moderator Emeritus
2006 Honda Accord
There is usually a small sticker on the computer in the rear access panel on the drivers side in the trunk area where the rear washer bottle is. At least it is that way for my 97. It might be the same way for your truck. Check there.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
On the 02-05 Current model line, the number is located on the passenger side behind the C pillar trim. You may have to take some of the trim off to get the code. I'm not 100% sure but I do know its there according to some members.
airjeff
White Bear Lake, MN
'04 Eddie Bauer 4.6
I had to find mine after I got the X. The dealer wanted some huge amount of $$ to plug in thier scanner and read it. It is on the C pillar. Just pull the weather stripping back and release the top trim piece. It's on a little computer module back there.(on a sticker) I had the link above bookmarked, but it doens't seem to work.(it used to) If you do a quick search on google you'll save a bunch of $$.
efox575
Raleigh NC
2002 Explorer E.B.
yeah this was the first question I had for the forum and airjeff is correct pull off the rear passanger door weatherstripping and remove the two clips holding the trim peice on if you have a small mirror long enough this all that you really need to do ,but its tight very tight I dropped my mirror twice while trying to see the numbers and it took me longer to recover my mirror than it took to get the code also it took me a couple of min.s to figure out the 2's from 5's since I was looking in a mirror upside down but there it was good luck
