Spenser Cammack
- November 20, 2018
- Tumwater, WA
- 2003 Sport Trac
Bought a used 03 Sport Trac in April. My son broke the fob, bought a replacement and worked, then shortly after the fob will stop working, I reprogram it and it works once or twice, and then stops. Also the key will not open the door, will start the truck but not unlock the door. Only way to unlock the truck is with the key pad, but it starts honking as soon as it is activated. When the code is entered it stops. Not sure if this is a programming issue, transponder issue, key pad, or something from buying the replacement fob. I also have a 2nd key I want to cut and program but haven’t taken it in to program it, worried to do it with this issue going on.
