1Byounkin
- February 8, 2010
- Gallatin, TN
- '91 4x4 XLT
I have a problem that just pop up. All at once if you turn the key to start the starter would never turn. Every relay clicks like normal. You can turn the key to ON and touch the two post, which would start it fine. If I put a test light on the wire (slide on) that is from the key switch, you would get nothing when the key is turned. Yes one side of the solenoid is hot, like it should. And you can all so jump each post (big post) or Hot post to the small post (from the key switch) and the solenoid would kick just fine. I belive it's something in the start circuit.
What is the best why to trouble shoot this?
