wisedetailz
- May 16, 2014
- Baltimore, MD
- 2002 Ford Explorer
Hey everyone, I recently added some amplifiers/subs to my truck and I was wondering if anyone knew IF the fuse box under the steering column had an "accessory fuse" or a "switched power" fuse I could tap into for my remote amp wire.
I need to locate a fuse/wire that is only "live" when the keys are in the ignition and turned on. Some people refer to these as "switched" wires/fuses.
So, when the key is in and turned on the fuse is active and when the key is out and the car is off the fuse is inactive.
Open to ideas and suggestions. Thanks for your time.
