Ok- so it has been a while. Been trying to drive it aggressive on the street and hit some big holes and corner hard. I also took it on some high speed stuff through the field and flexed it a little. Not major.
Anyway, looks like I am using about the same amount of up travel on both sides. 3.5" or so.
This leaves me about 3" extra down travel that is only used in heave articulation.
So with this in mind- The 12.1" travel shocks I have are 19.65" fully compressed. If I put in the 14.1" travel shocks (non resi
985-24-007), they will be 21.85" full compressed. This will make my setup have 2.1" less compression. So that means I will still have about 1"+ of up travel that won't be used in normal driving with the 14" shocks. The 14.1s will give me about 5" of up travel. This will also result in 4.2" more down travel than the current setup.
I also discovered that the piggyback 14" reservoir shocks (985-24-055) have a little shorter compression length of 20.85" so I could go with them if I don't have enough uptravel for articulation. It will be $100 more per shock and will only result in 3.2" more down travel, but I will get 6" of up travel.
So anyway, I need to flex it up and see which one would be more useful. My usual spot to check travel got sold so I need to find a new spot. My dad is also installing a vehicle lift in his garage soon- that would be prefect for checking max droop. Otherwise I will see if the old high lift can max it out. I am expecting that I will need to use limiting straps too- but I want to get the most travel possible.
Thinking the 12" shocks can get used on the rear. I would love to outboard them. My bilstiens are too long in their new setup- they bottom out when I have the rear end fully loaded. Wondering if I can find some sort of upper mount that can mount to the frame and get them into the wheel well. Especially since I have the full width rear end. The super duty mounts won't work- I need something that would orient the top mount the other direction. Seems like I have seen something that is cast on the lower end. I will have to look around. I could also build something out of tube.
Also, Fox lists performance shocks, then factory race shocks 70/30. I think I will call them and ask what the difference is. Assume the performance have different valving. I would like something a little softer if possible.
