Knocking then smoke *engine* | Ford Explorer - Ford Ranger Forums - Serious Explorations
Coos Bay, Oregon
1992 Eddie Buaer
I was on my way to check out a 73 Ford when my explorer started to make some funky noise's while driving (knocking). I stopped the X while running and proceeded to look under the hood. When i stepped out of the car it died. No power whatsoever. I ended up mess'n with the battery terminal and power came back to life. I fired it up and the damn belt by the ac unit started smoking. Im thinking the ac unit froze and the belt was smoking. Any insight on a replacement belt to by pass the ac unit would be helpfull, or possibley another look on wtf happened today to my bitchn X. I was thinking it was a ground wire cause I was un-able to get my new battery to work while sitting in the road dead....
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
if it is indeed the ac compressor... then you can bypass it by using a belt for an explorer without ac
Coos Bay, Oregon
1992 Eddie Buaer
Do you kno where the best place would be to pick up a replacement belt that would bypass my ac.? Thanks for the help.
jimbo74
Elite Exploder
Nor*Cal
2001, F150, XLT 4x4
any parts store
just have them look up the belt and tell them it doesnt have ac
marragtop
balt, md
91, 92, 95, and 2000 xlts
Sounds like the clutch on the AC locked up. As previous post states you can get a belt for the X 4.0 motor without AC.
Coos Bay, Oregon
1992 Eddie Buaer
Is there a way I could replace the clutch on the ac unit? Id really hate to loose my ac.
Robb
You need a new compressor, I don't think you can even purchase clutches by themselves. And there isn't any gaurantee that it is the compressor itself that hasn't locked up, not the clutch.
You should probably pick up some new battery cables while you are at it.
ps: please limit your signature to six lines or less
