KOER Codes 090 & 157 | Ford Explorer - Ford Ranger Forums - Serious Explorations
DesertGeezer
Mojave, Ca
1993 Eddie Baurer
I have a '93 Explorer that was throwing MAF and EGR KOEO codes, I cleaned both and now have a good code 111, but now am throwing both a Code 090 and Code 157 on the KOER test. HELP!!
Thanks
Sams01XplrSprt
Southern Cali Explorer
Newport Beach California & Bay Area California
2001 Sport (sold)
welcome
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
DesertGeezer
Mojave, Ca
1993 Eddie Baurer
Yes, the codes showed up afterwards.
UPDATE: Replaced MAF, cured problem. Still don't know what a Code 090 is however. :D
I used an Innova 3120 reader and it worked great.
Thanks again.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
The only 90 code I can think of (or series of pulses that could be interpreted as 9) is from the cylinder balance test. Some code readers interpret the 9 pulses that indicate a pass on the cylinder balance test as 90 (or 090 if the reader is going to insist on 3 digit codes). When you performed the KOER test, did you trigger the cylinder balance test at the end?
