lack of power - fuel pump going bad?
Corn98632
2005 Ford Explorer xlt
I am stumped.
I have an 05 explorer xlt, 4.0 SOHC V6 with 191K miles.
With about 8K in repairs
In the past 6 months I have replaced, the front wheel hub assemblies, rear tie rods, upper and lower ball joints, TRANSMISSION, replaced the fuel filter, oil change/air filter, had the throttle body cleaned, had the idle control system reset, ran some seafoam engine cleaner through the gas tank, replaced the catalytic converter, all 4 o2 sensors, new spark plugs and wires. I think that's it.
Rough idle at stop lights, doesn't bother me too much. The problem I'm having is that it's sluggish. It takes a good 10 seconds to get up to 35 from a stop. Going 65 on the freeway up a hill, and it just feels like it doesnt have the power and doesnt want to go. Going up a hill the other day in town went from 35 to 20 and didnt want to go, then it just surged and started hauling.
Have checked, no signs of a vacuum leak. Was thinking maybe intake manifold gaskets or PVC valve, but mechanic says no leaks that he could find.
please help!!
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
I am stumped.
please help!!
@Corn98632
Sounds like possible insufficient fuel flow. '05 has returnless fuel system, varies fuel pump speed to maintain constant fuel pressure. These models use a Fuel Pressure and Temperature Sensor to command data to the PCM (computer). Usually, a fault generates a trouble code, and turns on the Service Engine Soon light. Is that light on? Need to check for codes before proceeding, which likely involve measuring the fuel pressure at the fuel rail. You may find that the pump is at fault. imp
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
What about the other cats?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Corn98632
I had the entire cat thing replaced. There were three of them on there.
I don’t know what “checking at rail” means, I’ve seen it a lot. While the engine is running but idling my scanner says the fuel psi is about 32-35.
No check engine or lights are on.
Everyone that’s scanned it has said that it says something not being able to communicate with the computer or something not complete or something like that. But they haven’t given me the code. Someone said that it said the vins don’t match so that means that at some point in time someone has replaced it. The people at the tranny shop said that it would say that because there’s an internal checklist it needs to complete but that was 3,000 miles ago, it should have completed that by now.
I don’t know if anyone has checked the cylinders while in there.
Mbrooks420
High Voltage.
EF Vendor
Checking the fuel pressure at the rail is hooking a gauge up to the fuel path directly where the injectors are fed from. Mechanical fuel gauges are cheap, and hooking one up to the Schrader valve is easy.
imp
Location
@Mbrooks420
It is exactly as you say, but I think the '05 4.0 has no Schrader valve. AFAIK, my '04 does not. Maybe ALL 3rd. gens. do not. Or before "returnless", maybe they did. At any rate, if no check-point is provided, opening up the fuel connection is necessary to hook up a gauge. imp
C Misfire/Lack of Power/CEL Under the Hood 8
W Help !! - rough idle / lack of power Under the Hood 7
K Complete lack of power Under the Hood 7
D lack of power/rough idle when hot outside Under the Hood 0
X '07 OBDII lack of communication Under the Hood 4
T sometime a warm a/c is not lack of freon Under the Hood 0
C Lack of Response. Under the Hood 3
M Brakes, or lack thereof Under the Hood 12
D Power steering Under the Hood 2
domct203 Total loss of electrical power when turning off engine Under the Hood 5
D No Power at all after replacing shift cable, 2002 XLT Under the Hood 4
C 1994 Crank no start - How to disassemble power distribution box? Under the Hood 0
E No power 1993 explorer Under the Hood 4
EGruner 2008 RF Power Seat Pigtail Diagram Under the Hood 4
J Power Steering Issue on 2003 Ford Explorer 4.0L V8 (Is dealer at fault?) Under the Hood 7
P Power steering fluid? Under the Hood 5
U 95 Explorer loses power Under the Hood 1
E Intermittent tap and power loss Under the Hood 0
P Power Surging Idle Help Under the Hood 9
J Power Steering pump spline Under the Hood 1
W '99 explorer power window fuse location Under the Hood 1
D How much power can i get out of a 4.0 SOHC Under the Hood 5
L 1999 ford explorer power steering pump Under the Hood 1
T 99 explorer trouble starting, loss of power and dying. Under the Hood 6
J Leaking Power Steering Rack Under the Hood 4
U Power steering cap popped off Under the Hood 3
L loss of power and instrument cluster Under the Hood 1
D power windows Under the Hood 1
M Power locks stopped working Under the Hood 1
S Power Steering pump & bracket removal for timing cover Under the Hood 0
Scott B. Power Steering Pump Question Under the Hood 0
D Power Steering Flush Under the Hood 6
A 2002 Explore 4.6 power issues Under the Hood 5
M Bolt locations for A/C & Power steering pump bracket Under the Hood 1
J 01 Ranger 4.0 SOHC - No Power - even after timing chain replacement Under the Hood 7
M 06 XLT 4.6L V8 Power Boost Wanted! Under the Hood 0
9 help--lossing power-- Under the Hood 3
A Is this a power steering hose? Under the Hood 1
N Power steering/Hard to turn Under the Hood 2
T '00 5.0L Power Steering Pump Under the Hood 2
S 99 5.0 loss of power on hills? Under the Hood 2
C Electrical problem, continuous power to fuel pump. Under the Hood 0
N Low back pressure power loss questions. Under the Hood 16
S rough idle, loss of power under acceleration Under the Hood 6
K 2003 Explorer Power Steering Pump Question Under the Hood 2
sport97 Bad idle, low on power Under the Hood 7
G How much power with the 4.0L bottom end handle Under the Hood 4
T 93 4.0 expo rough idle power loss ((PLEASE HELP)) Under the Hood 32
R Anyone had a power steering pump pulley move toward the pump body? Under the Hood 2
W 2006 explorer lost power and stalled wont re start Under the Hood 1
Similar threads
