Laptop formatting/installing XP Pro
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
1975 Ford Bronco 4x4
I'm trying to reformat a Toshiba laptop and add WinXP Pro. I have an XP Pro boot CD, and when I run the setup on it, it loads all the drivers and whatnot fine, but then it stalls out on "Starting Windows" mode. Any idea? This laptop was all fawkered up. How can I format it, then install the XP.. and not have to use the boot disk to do the formatting?
celly
disturber of the peace
calgary
99 eb 5.0 awd
I just did a fresh install on a PC at work. Somewhere during the XP install, you're given the option to completely overwrite the existing partition and then install XP into the new partition. This completely wipes out all the existing data on the drive, so be careful.
If you go this route, make sure to hit "Windows Update" for all the patches. You then have to install all your applications again which takes time. I also did sort of a clean install on my machine at home, and a fresh install definitely cleans up a lot of inherited problems. What it won't do is fix any technical problems you have with the hard drive itself. My home machine runs way better since I did this.
Be careful and good luck. Don't forget to back up your data, including your email files (pst files) if you're using Outlook.
etc
Dead Inside
Miami, FL
'96 XLT 2WD
New laptop?
Use a floppy boot disk, or if you don't have a floppy, a cd boot disk with dos and format files on it.
http://www.bootdisk.com/
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
It was locking up before it even gave me the option to partition and blah blah.
I just retored it back to the oldest date I could (only January), so hopefully that'll do something. Got my .pst file(s). Hope I remembered everything else! This is the bosses laptop! :eek:
etc.. the only floppy is the one infront of the computer. :p
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
Blee! Howard! :p
I have gotten no where. It gets stuck at this screen.
etc
Dead Inside
Miami, FL
'96 XLT 2WD
:p
Hehe, I figured as much :D . Try burning a bootable cd with the dos files to format that sucker.
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
Yeah, right after I solve nuclear equations. :p Is there a website where I can do step-by-step directions?
Howard
Moderator Elite Explorer
Staff member
Moderator
Milton Keynes
1998 SOHC UK SPEC
Run a CD cleaner or clean the CD lens. Also make sure that the windows CD is not scratched. Check that the ram is seated properly. Not much else you can check on a laptop.
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
I searched for "freezes at setup is starting windows" and it looks like a lot of people have this problem. Right now, I am using my windows 98 boot disk to format the HD. Then hopefully I can make an early withdrawl and pop my XP in and go from there. If not, I'm overnighting it to Buckingham.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
If all else fails, try copying the i386 folder from the CD to the C drive. I would recommend doing a fdisk to wipe the partition info.
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
How do I do an fdisk with XP? Can I do it through this Win98 boot CD? I really wish these things had floppy drives right about now.
Blee1099
Evil Asian
Moderator Emeritus
EF Vendor
Elkridge, MD
I have a bootable CD and floppy with Fdisk and other utilities..
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
I think we're big pimpin now. I'll get back to you guys in... 11 minutes.
huskyfan23
Rah no Hans Bwix
WA
1994 XLT 4x4
WTF? No floppy?! Is the thing a Mac? Is the CD scratched? I had a similar problem, copied the CD, and didn't have it again. I guess you can burn the bootdisk files from that site to a CD, enter BIOS setup and change the boot order so the CD-rom is first in line.
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
Doood.. laptops don't come with floppys anymore! At least in CA. :p
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
Okay.. wtf. I installed Win98 flawlessly. But when I go to upgrade to XP Pro.. it locks up in that exact same place. I am trying to use two different CDs (one boot I made from my original) and both are stalling in the same spot.
Could it be a CD drive problem? I know the boss beats on it with his finger when he gets frustrated. But it did load 98 perfectly.
What are my options? Can I install Pro from a external HD I have (instead of using a CD)?
huskyfan23
Rah no Hans Bwix
WA
1994 XLT 4x4
So this didn't have XP before? It had 98? Sometimes this can happen when the BIOS is not up-to-date. How old is the laptop?
I'd try swapping the HDD to another laptop and installing that way.
Does this happen at the very end of setup? Or is this the very beginning?
section525
sextion525
Moderator Emeritus
Red Bluff, Ca
This laptop had XP Home orginally. I think its about a year old.
It happens at the beginning of setup.
huskyfan23
Rah no Hans Bwix
WA
1994 XLT 4x4
Are you actually getting into setup? I don't see why it would say starting windows if you pressed a key to boot from CD. Did you manage to reformat? I think you can use the recovery console and run fdisk.
