TreDen
- November 4, 2016
- 1992 Explorer
Good evening guys,
Long story short, the explorer has started to break down more and more in the last year. Every time it is something simple, or less then a hundred bucks, and I change it myself and get it back on the road.
I've added some photos, but pretty much it is just a traveling camping/fishing truck and we have driven it all over the country multiple times. The girlfriend and I are living in the Florida Keys for the winter and I lost the clutch. She thinks I'm too emotionally attached to the truck and is trying to convince me that it's time to let it go. She won't let me take it to the shop for a grand to fix it up over concerns it will crap out in the near future.
That being said, I have convinced her that I can fix it myself for under 400 bucks. It's a win win for me. I love working on this truck and learning new things. When I bought the truck years ago I didn't know how to change the oil and now I am changing the radiator and alternator on the side of the road in the middle of the countryside to get her up and running if need be. I want to attempt the clutch.
I just want to make sure it is worth fixing, or if it could be a way bigger problem then I think.
This is what happened.
A month ago I was having trouble shifting into gear. I would push the clutch in with no resistance and it was very hard to shift into gear.
Where my truck was parked there was fresh fluid that had leaked out, I checked the reservoir and it was empty. I added brake fluid. The clutch came back and I drove it for a few days. Then I lost the clutch again. This time there was still fluid in the reservoir but I wanted to bleed the system.
I went and bought a syringe. I filled it with brake fluid, attached it to the clutch line that runs to the master cylinder and I forced fluid into the system while pumping the clutch pedal and bleeding it down below. I have never had so much pressure in my life. The truck drove for a week.
I thought it was fixed...but, it got a lot worse. I would start it up, throw it in gear, drive a little bit, and then it would be impossible to shift. I would go to add fluid but it was full.
Now, when the truck is off, I can shift into gear. When I start the truck in gear, the truck jumps forward and dies. I have no clutch at all, no pressure. If the truck is running I can not get it into gear. I let it sit for two weeks, started it up tonight and I put it in reverse, it went into gear, but the second I started to roll I lost the clutch and the engine was stuck in reverse. I shut it off and I could shift through all the gears again. I turned it on and it would not shift into gear. I then started it in first gear and it would just die, and try to roll and shutter to a stop. I have no clutch.
I've found a few videos and a great write up on this forum. The girlfriend is giving me a week to fix it or she is going to fly home to get her car and I will be stuck with paying someone to remove the truck from our one and only parking spot.
It's a small space, drive way but I now I can do this. I am planning on getting some of those red truck ramps, to raise the truck up a little. 92 4-door 5 speed.
Before I rip the thing apart give me a heads up on how bad is it going to look inside there? Am I going to need to replace everything? How much for all these parts you think? I'm thinking full clutch assembly kit, slave cylinder, and fly wheel? Some pressure plate?
Could it be something as simple as my master cylinder?
I'll answer any questions, I'll post updates. Thank you guys
http://imgur.com/a/PcVvd
