Explorer_PL
- November 16, 2007
- Rockland County, NY
- 06EB V8
So at 138 k miles, the right rear bearing started making noise, and when I lifted the car, the wheel woobled like crazy. Si I tightened the 35 mm axle nut and that got me additional 500 miles while I shopped for the bearing. The dealer wanted 120 bucks, I said thanks. I looked on line and found them for 90 incl S&H so I ordered it, and also the snap ring (you can use the old one).
AutoZone had Timken for about $ 60 but when I went to get it, it read "Korea" on it so I said no. I ordered one from Ford Dealership on line, it came in as Motorcraft part, and on the bearing it read "Korea" !!!!
I took out the knuckle, gave it to the local shop, they did the press for me for $ 50. I did already few hundred miles, all is good so far.
The worst part of this job everytime is the e-brake re-assembly, what a pain, unless I do not know something, or not using proper tools.
It took me 45 min to take the knuckle out, about an hour to put it back together. But I had it apart about a year ago when I replaced the ABS ring on that side.
