Thanks for the captures man, that`s awesome.
Negative on the radius arms, they didn`t bend or contact the frame at all.
What I`ve bent is my lower coil cups, they both bent on the outside, now my coils have a mild arc towards the tires. This is something I kind of anticipated, I saw it on Bronco forums, after I had it mounted. The fix is pounding it flat and welding a circle of plate steel to the underside. I sure wouldn`t mind some jounce shocks up front, maybe soon...
On an unrelated note I have a couple other issues that were present before the contest.
My steering box has had a small leak from the sector shaft for a while, probably due to my efforts to take the pitman arm off. Even though I had a puller I had to pull so damn hard on the wrench that I must have tweaked it. I`ve had this come up before, and had to replace the whole box because I couldn`t find a way to have it repaired.
My manual transfer case shift mechanism is wonky. I don`t understand what I could have done in the build to mess it up but I`ll have to devote some time to figuring it out..
The problem is it goes into 4 hi with the slightest of movement on the pull and if I pull it all the way back to where it usually engaged 4hi it will actually go into neutral, so to have 4hi it actually has to sit almost at 2hi. AND it`s a biotch to get it out of 4hi and back into 2hi, I gotta ram it forward a few times, jiggle it, etc. it sucks. On the other hand when it`s in 4lo it`s tight and can`t slip out, and that`s what I ran that course in.
Anyway, if anyone knows a t-case trick to look for I`m all ears.
Woohoo!
