leaf spring bushings on my X! | Ford Explorer - Ford Ranger Forums - Serious Explorations
jake122288
Pleasantville, iowa
1994 4-door xlt 4x4
Ok i have a 94 Explorer. and i replaced the shackles for the rear leaf springs...upon taking out the bolts that connect the shackle to the leaf spring, it pulled the whole bushing with it (inner metal sleeve and rubber) but left the outter metal ring of the bushings...how do i get this removed from the leaf spring so i can put in my new bushings? i tried pliers and vise grips and i pb blasted it to try and loosen it but no luck. Any recomendations
SuRrEaLNJ
hail to the king, baby!
out of my mind...
MUNK 07 Focus 97 XL1200C
heat it with a torch and you can drive it out with a punch and chisel. as the sleve folds in upon itself it will loosen the fit and drive out
id recommend that you check that you need it removed by test fitting your replacement bushings as some aftermarket bushings will re use the old outer sleve
if you do replace any of the other bushings make sure to not remove the sleve on the frame to shackle bushing
jake122288
Pleasantville, iowa
1994 4-door xlt 4x4
yup it needs removed..i already have the new bushings and they have the outter sleeve and they arent coming outta the new outta sleeve lol
