Leaf Spring Rear Eye Bushing - Too Small | Ford Explorer - Ford Ranger Forums - Serious Explorations
clevalley
Warrenton, VA
2000 Explorer XLS
2000 Explorer 4-door -
Bought Energy Suspension 4.2124 kit and have a problem with the front eye bushing being too small.
I removed the outer sleeve of original bushing as it was severely corroded... the Energy Suspension directions do say to remove both OEM outer sleeves for front and rear eye. If I left the outer sleeve in the bushings were still a bit loose, but they were corroded so bad they would have chewed the new bushings up real quick.
The inner diameter of the front leaf spring eye is ~ 45mm - the OD of the rear eye bushing is ~40mm.
I called Energy Suspension and they were of no help has the kit is for a 91-94 and I have a 2000; they do not make the kit for a 2000 and will not support it. I tried to ask them if they could look up bushing sizes based off of my measurements but they said I had to speak with a re-seller as they do not sell directly to the public - nice customer service. :thumbdwn:
I need to make new sleeves to fill the gap and looking for some advice.
Blacksheep Josh
Slinky+Escalator=Fun
Statesboro, GA
'01 Ford Ranger, RIP 93 X
It's really not their fault. You bought a kit for an entirely different generation vehicle and they're not a retail store. I have to defend them in this case. Your best bet is to call up Summit Racing and speak to a rep through them. Or just go factory.
clevalley
Warrenton, VA
2000 Explorer XLS
Yeah you are right - but the guy was snotty on the phone... I did explain the kit was for a different year and was looking for him to search to see if they manufactured something to fit based off of ID of the rear eye - this is where I have the issue of their customer service. Maybe he was having a bad day.
Either way, I need to figure out a way to sleeve to fill the gap or go OEM and press it in - but wanted to at least attempt to use what I have and am open to outer sleeve ideas.
Thanks!
clevalley
Warrenton, VA
2000 Explorer XLS
I think I may have found a fix; American Sleeve Bearing sells a steel bushing with a OD 45mm, ID 40mm, length of 70mm (will have to trim the length down) - the sleeve is coated internally with a PTFE liner and should be nice and smooth for the poly bushing, and fills the gap.
REWINDER
S.E. Washington
99 EXPLORER SPORT
Energy suspension part # P 3.2125 1.75 barrel dia. For a 9/16" bolt dia. Made for a Chevy truck. Leave the old bushing sleeve in the spring eye. $20 on Amazon. Randy
