Leaf Spring Squeak | Ford Explorer Forums - Serious Explorations
Leaf Spring Squeak
sk1er17
My "Jeep Thing" itches...
NJ
'98 Sport
Hey, I thought my bushing from my 4 door leaf packs need to be replaced but i discovered the squeak is caused by my add a leaf (the larger one). Is there a way to buy leaf spring spacers (like the ones that come on stock packs).
Or has anyone found a substitute?
Thanks
Any old grease at the leaf ends will stop most of the squeeks. My aal instructions said to grease the ends to prevent noise, did you read the instuctions? :D
Lol yea i read the instructions.. And i greased them up. Its been a few months and many off-road adventures and now they began to squeak. I re-greased them already and that stopped the squeak, thats how i determined the problem is deffinetally them. I was just thinking there was a place i can buy those spacers because the squeak is destined to return.... grease does wear away :p
Greasings been working... but i was right- it wears off everytime i hit the trails. Just not as severe. Im gonna try some marine lube- maybe that'll last longer since it protects against harsh salt water.
Either way.. does anyone know where i can get those spacers that sit between the ends of the leaf springs?
Or any good substitution for those? I was thinking of wedging something in there but im not sure what material i should use and if it would stay put.
****I have the DOUBLE AAL's.. i think these are more prone to squeak because there are two leafs without spacers AND they really push hard on the stock leafs. When i put it on a lift at work the tips still touched, i had to hammer in a pri-bar to get about 1/8" between the ends to lube em up!
