bs46488
- September 11, 2005
- Los Angeles, CA
- 1997 V8 AWD
I'm sure this is a stupid question, but.....
I installed a drain plug in the pan of my transmission (to make fluid and filter changes cleaner)
Anyway, just as I thought, it leaks. I got a nice tight hole and the kit has a rubber ring on each side, plus an o-ring on the drain plug. It is leaking from the hole in the pan, not the drain plug. I want to just caulk around the bolt, can I do that? Also, what type of stuff do I caulk with?
I'm not really into draining the pan to fix this the proper way.
Thanks....
Thanks....
