Leaking front Differential Cover | Ford Explorer Forums - Serious Explorations
Bzz
BC <--That's in CANADA..=)
'97 XLT
I have a 1997 Ford Explorer XLT. I noticed oil stains underneath the car, on the garage floor the other day.
Upon closer inspection, the leak seems to be coming from the bottom of the front differential cover.
So, I figure this should be a simple gasket change...but obviously, nothing's that simple..:rolleyes:
My question is, what's the easiest way to access all the bolts that hold the cover on?...
Can I drive my Explorer onto ramps that I use the change the oil...unbolt the 3 bolts that hold the differential to the car and hope that the differential drops down a few inches (still attached at the input shaft and axles), below the front cross member, so that I can get at all the bolts to replace the gasket?
any other advice for those that have got to it?..preferably without removing any other parts..
thanks for the quick reply..
dropping the diff FULLY would be my LAST resort..there's GOTTA be an easier way to access the 10 bolts..:D to replace a gasket...
...so no one has tried just removing the 3 bolts holding the differential up and seeing if it will drop down a bit to access all the bolts on the diff cover huh?..:(
you'd have to get it to drop about 8" or so. thats a lot more play than i think you will get out of the halfshafts. i dont think it will work.
Did just dropping the axle work? I have to do the front cover seal on my 2000 Ex. I'm trying to find the easiest way as well.
Hoppy
There's enough room on my '96 to unbolt the cover, remove it, clean the gasket face and install the cover again. You'll need to use a flex-head wrench for this, though.
