Leaking Power Steering
Johnnyr2961
2003 4.6L Explorer
Hello All,
I have a 2003 4.6L Explorer and I have a power steering leak. I am pretty sure it is coming from a hose and I think this is the exact replacement I need from Advance Auto http://shop.advanceautoparts.com/p/...ng-35759/20990092-P?searchTerm=power+steering
My problem is getting it changed out. Is there any special equipment I need to get loaned out from Advance such as a pulley remover or anything else?
Thank you.
L badly leaking power steering fluid Stock 2002 - 2005 Explorers 8
K Leaking power steering fluid lines Stock 2002 - 2005 Explorers 8
M Transmission leaking with photos Stock 2002 - 2005 Explorers 12
J A/C Leaking r134a,,,, but I can't find the leak,, even with UV dye. Stock 2002 - 2005 Explorers 9
D 4.0L V6 Engine Leaking / Burning Fluid Stock 2002 - 2005 Explorers 2
P Rubber Seal Around Windshield Leaking Stock 2002 - 2005 Explorers 3
G Leaking around engine block Stock 2002 - 2005 Explorers 5
B Fuel leaking out exhaust Stock 2002 - 2005 Explorers 9
C '03 XLT leaking fluid Stock 2002 - 2005 Explorers 2
M What is leaking? Stock 2002 - 2005 Explorers 8
R 2004 eddiebauer 4.6 v8 leaking under thermostat housing Stock 2002 - 2005 Explorers 1
T Replaced rear main seal, leaking again, replaced again, now leaking Stock 2002 - 2005 Explorers 8
Q 2002 explorer 4.0 leaking anti freeze Stock 2002 - 2005 Explorers 5
C Green paste leaking Stock 2002 - 2005 Explorers 3
P Lower thermostat housing or manifold leaking Stock 2002 - 2005 Explorers 6
H Rear Windshield Fluid leaking Stock 2002 - 2005 Explorers 4
J Leaking Antifreeze, please help Stock 2002 - 2005 Explorers 10
S Where is the coolant leaking from? Stock 2002 - 2005 Explorers 4
L Upper and lower pan gasket leaking Stock 2002 - 2005 Explorers 2
J Rear axle specification? Remanufactured axle leaking! Stock 2002 - 2005 Explorers 5
M Leaking fuel from vapor canister vent solenoid Stock 2002 - 2005 Explorers 3
H Refrigerant leaking Stock 2002 - 2005 Explorers 6
T What is leaking? Stock 2002 - 2005 Explorers 44
D still leaking water in pass floor board... Stock 2002 - 2005 Explorers 8
J 2005 Leaking antifreeze Stock 2002 - 2005 Explorers 2
S Front CV axle shaft leaking. Stock 2002 - 2005 Explorers 2
F Coolant leaking Stock 2002 - 2005 Explorers 2
D yellow fluid leaking rear axle Stock 2002 - 2005 Explorers 0
S 05/01 (2002) XLT 4.0 leaking coolant under driverside Stock 2002 - 2005 Explorers 4
M Anti-Freeze Leaking Stock 2002 - 2005 Explorers 15
M Rear diff empty but not leaking? Stock 2002 - 2005 Explorers 11
V 2002 XLT 4.6L misfires and leaking coolant Stock 2002 - 2005 Explorers 3
K Leaking water Stock 2002 - 2005 Explorers 0
S Help! - Leaking warm water near trans (Picture of source) Stock 2002 - 2005 Explorers 4
T Muffler Leaking Water Stock 2002 - 2005 Explorers 5
J Engine Coolant Leaking after replacing hose clamp Stock 2002 - 2005 Explorers 12
T Thermostat housing still leaking after multiple repairs Stock 2002 - 2005 Explorers 12
T Water pump bolt size??? fixed. But leaking. Stock 2002 - 2005 Explorers 2
2 can a leaking inlet manifold cause coils to go? Stock 2002 - 2005 Explorers 1
W What exactly is leaking here? (pics) Stock 2002 - 2005 Explorers 11
N leaking rear axle seal Stock 2002 - 2005 Explorers 4
J Leaking coolant... Stock 2002 - 2005 Explorers 5
W leaking coolant Stock 2002 - 2005 Explorers 2
W leaking coolant Stock 2002 - 2005 Explorers 5
3 Leaking? Dripping on headers Stock 2002 - 2005 Explorers 2
P Tranny fluid leaking from bell housing Stock 2002 - 2005 Explorers 6
M Front Differential Leaking - Easy solution? Stock 2002 - 2005 Explorers 1
S Leaking fluid right rear wheel Stock 2002 - 2005 Explorers 15
C leaking front differential Stock 2002 - 2005 Explorers 0
Similar threads
