jtmillan
- September 7, 2017
- Houston
- 2006 Explorer 4WD 4.0L
Valve Cover Leak, Intake Manifold, Oil Leak....
Looking for advice here. I need to replace both side valve cover gaskets on my daughter's 2006 Explorer 4.0L 4WD. Is it necessary or advised to remove the intake manifold in order to remove the valve covers for valve cover gasket replacement? Or, is it possible/advisable to attempt snaking the driver side valve cover under the intake manifold? I have not worked on this vehicle before so I am not knowledgeable on the various intricacies of what must be removed to access the items I need to affect.
Any confirmed advice is appreciated.
Jim in Houston
Jim in Houston
