freak
- November 17, 2007
- Location
- Northwest Ohio
- Pemberville
- 2000, Explorer XLS
2000 4.0 OHV. I get fairly bad ping when accelerating and especially when hot outside. The engine also overheats. The gauge goes up and OBDII says it's 230 degrees. I have to run the heater on max and I can get it down to around 212. I've changed the plenum orings. Checked for vacuum leaks with a home made smoke machine. I need to take this on a 10 hours drive on Tues in high heat and do not want the heater on the whole time. Timing is about 35 degrees at 65mph. Cleaned MAF sensor. Only code was lean. Cleared it and it hasn't came back again. Idle is high around 1200 then slowly drops to 800ish. Engine runs absolutely beautiful otherwise. I'm really desperate to get this fixed. Any tips appreciated!
