If you guys didnt see from my other post I recently got my EX stuck bigtime. I planned to go out with my friends target shooting in the forest and got in over my head. I was cruising down the trails smashing throught puddles and none were that deep. Small enough that my 4x4 XLT would go right through them, about a little less then hub deep.(they looked similar to the ones in the pic) Well long story short I went to drive through this one and ended up getting the truck high centered. Of course I was ill equipped for th situation. I had a friend try to pull me out but couldnt get enough traction. The next day we bought two 8000k comealongs and 2 tow straps. We ended up braking the comealongs, the cables started to fray and one got the cable all jammed up, and got the truck almost all the way out. I also bought a high jack which helped the most. I had to let the truck sit in the puddle for another night and come back the next day due to time restraints. With a little more lifting and pulling got the truck out. I always learn the hard way. 8 hours of pulling, shovleing, lifting and the truck was out. 4wd was stuck on but the truck still ran. I drove her back to the road and pulled off the 4wd motor and manually put her in 2wd. The truck still got me home 25 plus miles away. Now I have a storie to tell people on the trails, lots of experince gained on preperation before going out and what seems to be rod knock. Still trying to figure out what the noise is coming from the engine, but it dont sound good. you can hear it on my other post Rod knock? What do you think. And not to mention the whole time this was going on it was a raining muddy mess and a warm 40 degrees outside. Anyways im not gonna let it stop me from going out and having fun. I gained a few laughs and alot of knowlege. It is probably not the last time I will be in this situation either, just a little more prepared next time. Hope you all enjoy!!!
