vipjeff
- July 18, 2015
- 1995 Ford Explorer XLT
:exp:
My 1995 Ford Explorer XLT had most of the dashboard lights burned out (the instrument cluster lights which illuminate the tachometer, speedometer, etc). All the "instrument warning" lights were fine (check engine, brake, etc).
I thought while I was going to pull the instrument panel anyway I would upgrade to compatible LED bulbs.
I ordered these ones using the car make and model guide on their webpage.
These are the exact ones http://tinyurl.com/nf8attf I got.
I removed the cluster panel from my car, removed the 6 bulbs just fine, replaced them with these LED bulbs, everything physically went perfect and when I first turned them on they worked great for about a minute or less then they stopped working and I could not get them to come back on.
So I thought I blew a fuse so I checked all fuses in the fuse box to the lower left of the steering wheel by drivers doorjamb then checked the fuses under the hood. All were good.
Then I thought it may just be the LED lights so I bought the original 194 incandescent bulbs at my local auto parts store and swapped out the LED's for the OEM bulbs and to my surprise they did not work!
At this point I am thinking I may have fried something on the back of the instrument cluster like a resistor or diode?
There is a possibility it is the light switch however I don't think so because the light switch still works for headlights and the dimmer light works as well for my dome light and all other lights.
Anyone have any ideas? Any way to bench text the resistors and diodes on the back of the cluster I have a DVOM.
