boominXplorer said:I don't know about LED, they are REALLY bright, but put out no real usable light when shined on something. Ever see a led flashlight? The bulb looks REALLY bright but its alot darker when its shined on something.
Hundreds.BrooklynBay said:How many LEDs in a cluster would it take to make an adequate head light bulb? What about the high beams? It would probably be the same kind of bulb, just more LEDs in the same cluster. If they come out with it, I'm sure it will be like replacing a regular bulb. Maybe the existing halogen bulb could just be replaced with an LED headlight bulb as an upgrade. It should be able to fit all models of cars with Aero headlights. I doubt they will make a sealed beam conversion, but then you never know. I never saw an HID sealed beam conversion yet. The only difference with the HID aftermarket kits is that that they come with their own wiring harness to connect to a high voltage inverter/controller that put more voltage into them when they first start, then gradually decrease the voltage as the bulb warms up. LEDs don't have this problem. Fluorescent bulbs have this problem. If you ever saw one of those energy saving screw in fluorescent bulbs start when they were cold, you will see how dim they are until they warm up. The electronics that they come with don't force extra voltage into them to compensate for this problem.
The class III laser rating would rule them out for use as headlights, as you'd have to look at them from opposing vehiclesPdwight said:Luxeon Star Leds have a class III laser rating, they are not to be confused with the LEDs that are on flashlight key chains or the flashlights with an array of the same LEDs....they kick butt in a big way. I have an Executive Surefire top of the line flashlight and a Surefire 5W Luxeon Star L4 and let me tell you that the L4 puts out a cleaner white light with no "artifacts" in the light output like Halogen or any of the other rare earth filament bulds........in 3 to 7 years I predict that a filament light will be as antiquated as a 8 Track tape.
Dwight P
Don't fet me wrong, but I worked on laser printing systems for the big X for about 13 years, and have been laser certifiedPdwight said:But it hasent stopped them from selling them as flashlights, as a matter of fact they are the fastest selling flashlights on the market today. the police and all rescue people are using them because of longer battery life and better visibility....and they are used so people have to look at them all the time.
Dwight P
the argument is like the one 110 years ago about horses and automobiles...its not a question of if but when...........filament envelopes are going to as archaic as beta-max players in the next 10 years.
What seller? I would like to hear more about this hid lightjustin146 said:The only bad thing about the good Luxeon flashlights is their cost. I have seen heavy duty ones in the $200 range(multiple 5w LED). I got my 35watt HID flashlight off eBay for $175![]()
