LED headlight bulbs error message
davidmmm69
Location
Fall river ma
2010 Ford Explorer V6 Fall River Ma...
2002 Mercury Mountaineer
Thanks guys, I have been emailing the company back and forth. Im hoping they will send me the needed wire harness(s) needed to eliminate this error code. If not I'll find some on Amazon. Yes, I should have just purchased a more expensive LED that is error free bulbs. In the end it costs the same, just a pain to figure this out the hard way. No where on their description does it say you'll need the resistor harnesses, but I'll know for next time and hopefully everyone on here can benefit from my mix-up.
als bought the extra harness and still get the error messae on my 2010
RicanV84X4
San Juan, Puerto Rico
2010 XLT V8 4X4
So just to clarify nobody has found a CANBUS pigtail harness for running LED headlights that prevents the dash error messages?
94Eddie
2010 Mountaineer Premier
The headlights I have, Beamtech brand, from Amazon. They still give me a code error even after the company sent me a pigtail to eliminate the error. So I wouldn't recommend these if you are worried about getting the headlight error.
Honestly the error doesn't bother me, I hit a reset button and It goes away. The vision at night is worth it.
I just installed a set of headlight and foglight Beamtech LEDs. I got the error code that clears with a hit of the reset button. They are sending the pieces that will supposedly eliminate the error message. I am like you in that I will just hit the reset if they don't stop the error flash because the bulbs work amazingly well. Plus, you don't have to break the piggy bank to buy them. I just ordered a set of backup LED bulbs after seeing how well the front lamps work. The newer LEDs have been designed to mimic the halogen bulbs for light disbursement. Some bulbs need to be adjusted to insure the rotation of the LEDs are proper in the reflector housing. Mine went in as needed but some applications need to be tweaked. Next on my list is to start putting LEDs into the interior locations.
MotorCityFats13
Flatrock MI
2007 Explorer XLT 4.0L
search for "error headlight h13" and there are tons of options
the ones i bought from ebay work great
RicanV84X4
2010 XLT V8 4X4
Well these ones for $18 from a high rated seller do not work for the record.
Littleant
Location
Vermont
Orleans
2010 Mountaineer 4.0
Not to be a buzz kill or anything - but would like to remind everyone that your light housing was designed for incandescent bulbs to throw the light in the proper pattern - not only to allow you to see but also to prevent blinding other drivers. LED bulbs require a different housing to achieve the same results.
I see a lot of these 'retrofits' while out driving at night.
They aren't pleasant to encounter.
Maybe Explorers work well - I don't know. I'm sure it's different for various makes and models. But please pay attention to your fellow drivers - have a friend meet you on the road for an honest evaluation.
If people keep flashing their brights at you then please - take the hint.
1000% agree with EddyB. Have encountered them at night and many are blinding on low beam no less. I am sure they help to see better. I have seen them adjusted perfect and cause no issues for other drivers. So please adjust them so not to blind other drivers.
RicanV84X4
2010 XLT V8 4X4
can you check the resistance of those units vs a working H13 bulb
I checked a bulb and it was 1.6 ohm
1.4 ohm is what they checked out at... Shocked that .2 makes a difference... Can you send a picture of the ones you purchased. Seems there are only 3 different styles for sale on eBay.
MotorCityFats13
Flatrock MI
the only variable that i can see is that you are trying to use led's and i use hid's
RicanV84X4
2010 XLT V8 4X4
Just to follow up after trying multiple CANBUS load resistors to eliminate the dash error from eBay, the one from seller dt-autotech worked to eliminate the error on my LED headlights. Picture of this model is below. You definitely need a 6ohm resistor!
