This is part 2 to the Under Dash lighting mod I did several months ago. It took some thinking but I figured out how to do and LED setup under the rear seats and still have the seats fold up and down.
What you will need:
1/16 3/4x48 piece of aluminum angle ( Home Depot )
6 5mm Blue 13000mcd LEDs (grind the tips flat)
6 Resistors 470 ohm (the actual resistance was 463ohm)
Double sided tape
light gauge wire
The Stock
First cut a piece for the single seat to 12" and a piece for the double seat to 25.5"
For the single seat I drilled 2 5mm holes about .5" from each side of seat supports. And put an LED in each hole.
For the double seat I also drilled 2 holes roughly .5" from each support, then found center, and then found half of each side from center and drilled the holes ( if that gibberish doesn't make sense drill a hole roughly every 6")
Unbolt the seat supports and poke a hole thought the carpet and fish the wire to the plastic door trim under the carpet.
Wire them to a switch, I used the same switch as the under dash lighting.
and turn them on
Will get some pictures tonight of them on
Good Luck!
What you will need:
Double sided tape
light gauge wire
The Stock
and turn them on
Good Luck!
