Mikey*TX
- February 3, 2020
- Skunk Hollow, TX
- 2021 ST Star White
If you have done this or, are considering doing this, take into account the following:
1) The LED replacements on the market are not DOT approved. Installation in all states (I checked) is considered an illegal lighting modification. Class C Misdemeanor level.
2) The OE bulbs are brighter. They have two filaments providing better coverage and brightness compared to aftermarket LED push in towers. LED push in towers are capped. There are no LEDs in the rearward facing dome. This reduces visibility to those behind you. A such, the intensity of the hazard flashers is drastically reduced. Both filaments are activated by the hazard button vs only one when using the turn signal lever.
3) If there is an electrical issue and Ford can trace it to the turn signal mod, your electrical warranty is flagged. I verified this with a phone call to the SW zone office in Plano, TX
4) Get rear-ended ? A random check with several ins companies elicited the following response: Any modification to the vehicle lighting that is not DOT compliant will result in a related claim being denied.
5) Least important, no hyper-flash issue to deal with.
Your vehicle, your choice. Most important, your family's safety!
Mike
Mike
