BlakeOfDoom
- August 7, 2009
- murrieta california
- 91 Navajo
Is there any way to disassemble the hydraulic lifters in a 91 navajo? I had the heads replaced and since then there has been a persistent tick and misfire which has rendered the truck not drivable.
I deduced that a lifter was bad after I pulled off the valve cover, rocker arms and pulled out some pushrods; one of the lifters had a real "spongy" feel to it and was easy to compress and pull back up....
Instead of replacing the lifter is there any way I can pull apart the lifter; inspect it for damage, and reassemble it after everything checks out? What kind of damage should I be looking for? could the solution possibly be some kind of debris that got stuck inside? Or could coolant have gotten inside and caused it to collapse? :exp:
