lifting a 92 ex sport
johnsonhalo
hell hole arizona
92 Explorer Sport 4X4
right now my ex sport is on a 3" body lift, and i was gonna swap that out for a 4" suspension lift, due mostly to the fact that it overheats way to easily. with the body lift my radiator sits too high, and after installing 2 elcetric fans as well as a larger stock fan i still can't make a long drive during the day.
i've been researching the lifts and common problems that come with them, and it seems like the camber is the most common along with caster, not entirely sure what caster is. but if i swapped my front end for a solid axle rather than the pivot(i think it's a pivoting) i wouldn't have to worry about either would i?
also on a scale from one to ten, ten being i'll be ready to snap wrenches in half. how frustrating would this swap & lift combo be?
tweakedlogic
memphis, tn
'92 XLT
It's true, a body lift won't do that. Especially with two electric fans. There are a few causes. Your water pump lay need replacing, I have seen the impeller desentagrate but the rest of the pump was fine. Clogged radiator, only thing to do is change it, if you have a 5 speed, buy the auto radiator. It could be a cracked head or head gasket. Knowing the OHV, this is probably the culprit. Sorry to tell you that, but the first gen head have many weak points and fracture a lot.
As far as the lift, every body seems to love James Duff. Camber is how far your wheels lean in or out. Lifting a TTB will get you this \-/. the drop brackets that come with the lift will help keep the geometry correct. You will still have to get an alignment after installing.
johnsonhalo
hell hole arizona
Mmkay. I'll look into other causes, but the body lift is still gonna go when i get my suspension lift. With the 3" and my light rack i have to avoid parking garages. And the duffy lifts look nice, but they are slightly above my price range. I have the kit i want picked out, and also want to do the sas eventually but i was thinking that the camber was a big problem. Here's hoping it's not a cracked head
jd4242
va beach
92explorer&94 ranger
you still will have problems with your light rack hitting even with a suspension lift.camber is not a problem if you get a real lift,it will come with the brackets.if you plan on going to a sas then i would just wait to buy a lift as whatever you buy now wont work with the sas.JD makes a bolt on SAS kit,i would keep the bl on there till you can afford the JD kit,they make the best stuff on the market!!witch fans do you have and are they pushers?you still have the stock fan too?you have other problems if you are over heating
johnsonhalo
hell hole arizona
2 pushers. Just your standard electric fan from oriely. The superlift is what i was gonna go with. Even if i got it i wouldn't be able to install it until december due to uni. I'll consider a JD. Mainly i want to fix the overheating
MountainMonkey
canada
93 xlt
anyone got a link to this jd sas kit? very much intrested
jd4242
va beach
It looks like they haven't released the kit yet but all the parts are on there page
Foxracin
Mount Holly, NC
The kit isnt out yet. But you can get every part needed to do the swap now except the shock hoops. Thats is the only thing not final yet. Check out my build thread for pics of the setup. I run it on mine and am very pleased with it. Rides great on the road and works awesome off the road. Well worth the money.
If you interested in the stuff call James Duff and ask for my buddy Brad. He knows all the parts needed for the swap.
johnsonhalo
hell hole arizona
i missed their business hours today, but if someone has ordered their 5.5" lift is it possible to just get the parts needed for the lift, ie springs extended arms, etc?
Makahveli
Denver, CO
'92 Sport and AMG 300CE
I have a 92 sport 4x4 manual tranny, and the over heating thing got nothing to do with the lift, as when I bought my explorer it had a 3" bodylift on it and after 2 years I added a 4" suspeionsion lift to it. 4 years later I removed the bodylift as I was also rebuilding the top end of the engine at the time cause it wouldn't run right and was also overheating at times. I found that simply replacing the heads instantly fix the problem. Ran better, started up right away, the coolant wasn't dissapearing anymore.....By the way have your engine ever been rebuilt? If you go that route do it before removing the bodylift, more clearance............
johnsonhalo
hell hole arizona
i doubt it's been rebuilt, but i was considering doing that when i've got the time and space to rip the thing apart. did you just get stock replacement heads, or aluminum? and i haven't noticed my coolant disappearing, but that may have something to do with blowing 3 of my hoses on the freeway about a month ago. with the bl and the suspension lift how stable was it? i do daily drive my truck, and don't really want to sit ridiculously high, or get new tires...
jd4242
va beach
They don't make aluminum heads for the ohv
johnsonhalo
hell hole arizona
mmkay. i don't know too much about this engine if you couldn't tell. i'm more used to chevy(yah, i know) small blocks. thanks for the help so far by the way.
Makahveli
Denver, CO
Well as you see alot of us here upgrade to later model heads cause it really all we got that are cost worthy. I got rid of my bodylift to get rid of some of the wobbly affect I felt driving at highway speeds and I also simply didn't like the look either.
E Need help lifting a 2wd Explorer Sport Modified 1991-1994 Explorers 4
HSlough best shackles for lifting rear? Modified 1991-1994 Explorers 1
9 Lifting a 1991 Navajo need answers Modified 1991-1994 Explorers 8
H Lifting a 94 Modified 1991-1994 Explorers 1
2 Lifting my explorer Modified 1991-1994 Explorers 15
L.A.X Lifting A 91 For Dummies Link? Modified 1991-1994 Explorers 16
E Lifting a 93 Eddie four door Modified 1991-1994 Explorers 7
E Lifting Modified 1991-1994 Explorers 2
K lifting Modified 1991-1994 Explorers 8
C Lifting Modified 1991-1994 Explorers 6
C lifting my 1991 2 door explorer Modified 1991-1994 Explorers 5
F Little help Lifting my '92 Modified 1991-1994 Explorers 2
T lifting a 94 2wd Modified 1991-1994 Explorers 4
J lifting my first gen 1994 explorer Modified 1991-1994 Explorers 16
M need help body lifting my rig Modified 1991-1994 Explorers 7
S Lifting my '94 X 4" Modified 1991-1994 Explorers 7
E rear lifting Modified 1991-1994 Explorers 2
N 4x4 lifting Modified 1991-1994 Explorers 11
9 question about lifting Modified 1991-1994 Explorers 7
D Lifting Questions? Modified 1991-1994 Explorers 10
R Help with lifting options Modified 1991-1994 Explorers 7
R Question about lifting and fitting 35x12.50's underneath Modified 1991-1994 Explorers 5
Black Goblin Question about ride after lifting.... Modified 1991-1994 Explorers 9
Q lifting my explorer Modified 1991-1994 Explorers 25
V lifting my ’91 ex again. Questions! Modified 1991-1994 Explorers 4
sn0border88 Body Lifting Gap Modified 1991-1994 Explorers 5
G about axle pivot bracket and lifting Modified 1991-1994 Explorers 3
M 94 Dual Sport Modified 1991-1994 Explorers 4
E Brainstorming: Modified Explorer Sport 1991, what do to next? Modified 1991-1994 Explorers 6
S Inexpensive 16" wheels for 94 sport Modified 1991-1994 Explorers 14
C LED headlights (92 sport) (Success) Modified 1991-1994 Explorers 13
S 92 Sport 35k orig miles possible rear main issue Modified 1991-1994 Explorers 1
T '94 Sport - Rehab and Mod Project Modified 1991-1994 Explorers 6
O 91 4x4 sport overhaul. Modified 1991-1994 Explorers 6
X Planning a V8 swap in my 93 sport 4x4 5spd Modified 1991-1994 Explorers 2
E Sport 2 door to 4 door conversion Modified 1991-1994 Explorers 32
1 Will my 2v 5.4l fit in my 1994 sport. Modified 1991-1994 Explorers 6
J My 91 Sport Modified 1991-1994 Explorers 28
Siekyre My 92 Sport Modified 1991-1994 Explorers 19
D '93 Sport Expo/ trail rig build Modified 1991-1994 Explorers 130
2 Sport lift Modified 1991-1994 Explorers 7
1 Budget 2track 1994 sport Modified 1991-1994 Explorers 106
R Adding nerf bars to a 93 sport Modified 1991-1994 Explorers 7
mr cribb 93 Sport "Deep Purple" Modified 1991-1994 Explorers 80
M Explorer Sport bumpy ride Modified 1991-1994 Explorers 8
S My modified 94 sport Modified 1991-1994 Explorers 13
N 1st gen sport 4.0 possible build question Modified 1991-1994 Explorers 20
J Custom first gen sport truck bed Modified 1991-1994 Explorers 1
D 93 explorer sport, " The Complicated Procedure " Modified 1991-1994 Explorers 2
J xlt rear seat can fit in a 94 sport..?? Modified 1991-1994 Explorers 3
Similar threads
