Lifting the rear | Ford Explorer Forums - Serious Explorations
Lifting the rear
H munster
94 ex
Hey guys, whats the cheapest and easiest way to lift the rear of a 94 ex? My daughter wants to go up 2" and is on a tight budget. I dont want to do the spring over and a body lift is out.
you can get 2" lift shackles. Warrior shackles part #WAR153 are the ones usually used. There are also some new ones around called copperhead or something like that, I'm sure seaching will reveal them.
do a search for Warrior 153 shackle install.......... only get 1.25" from them, could also do a AAL. Other than that there be lift springs out somewhere, people have done the leaf pack of a F150, not sure of the year and whatnot. Plenty of info on these subjects inside the forum. Good luck with that :thumbsup:
No, you don't want to do a SOA that will give you about 5" of lift.
