Lift and tire size info for explorers
Lifts and max tire and wheel sizes for explorers
This is a quick reference guide I have put together based on information gathered from the Explorer Forum. Remember this is just a guide. You may have to do some fender trimming to fit these tires on your explorer. Others things can change what size tire you can run on your explorer. Like fiberglass fenders, rim width and rim backspacing.. I figured this would help some of you that were pondering what size lift to run what size tires.If anyone would like to add something go ahead and post it and I will add it to my list. If any of the moderators could make this a sticky that would be great. Hope this helps.
91-94 explorers.
No lift- 31x10.50x15 on 15x8 inch or stock (15x7) rims
1-2 inch suspension lift- 31x10.50x15 - 32x11.50x15 on 15x8 rims/ may require some extensive fender trimming
2-3 inch suspension lift- 32x11.50x15 on 15x8 rims
3-4 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rims/ may require fender trimming
4-6 inch suspension lift- 33x12.50x15 - 35x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift- 32x11.50x15 on 15x8 rims/ may require fender trimming
3 inch body lift- 33x12.50x15 on 15x8 rims/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift- 32x11.50x15 - 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 2-3 inch suspension lift- 33x12.50x15 on 15x8 inch rim
2 inch body lift and 4-6 inch suspension lift – 35x12.50x15 – 36x12.50x15 on 15x 8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 2-3 inch Suspension Lift – 33x12.50x15 – 35x12.50x15 on 15x8 rim
3 inch body lift and 4-6 inch Suspension lift – 35x12.50x15 – 36x12.50x15 on 15x8 inch rim
95-2001 (including 2dr 95 - present)
No lift- 31x10.50x15 on 15x8 rim or stock (15x7) rim
1-2 inch suspension lift - 32x11.50x15 on 15x8 rim/ may require some extensive fender trimming
4 inch suspension – 33x12.50x15 on 15x8 rim
2 inch body lift – 32x11.50x15 on 15x8 rim
3 inch body lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 1-2 inch suspension lift – 32x11.50x15 – 33x12.50x15 on 15x8 rim/ may require fender trimming
2 inch body lift and 4 inch suspension lift - 33x12.50x15 – 35x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 1-2 inch suspension lift – 33x12.50x15 on 15x8 rim/ may require fender trimming
3 inch body lift and 4 inch suspension lift – 33x12.50x15 – 35.12.50x15 on 15x8 rim/ may require fender trimming.
You may be able to run 33x10.50x15s inplace of 32x11.50x15s
2002-2005 Ford Explorers
Click here for lift option #1
Click here for lift option #2
No lift - 32x10.50 or equivelent in Metric Measurements on Stock Wheels (265/75/R16 or 265/70/R17) - no modification needed!
Dead Link Removed
