arco777
- April 6, 2008
- 1994 Explorer 2dr 4x4
Long story with only one picture - but any input is appreciated!
My 94's headlights will cut out after about 20 min of driving and I can feel the switch getting hot. I assume the switch is just growing old, as it is getting slowly worse over time. High beams behave the same though, which is weird because I don't think their current runs through the headlamp switch, rather it runs through the dimmer/flash-to-pass switch. Either way, low and high act fine with only one headlight connected; I take this to mean that my old headlamp wiring is just not sufficient to run the lamps for long. I don't trust it to handle the addition of auxiliary lights any better.
I decided I'd wire in a couple relays; two, so I retain hi/low and flash-to-pass functionality, and since they're 40A relays they'll also handle a pair of 55W auxiliaries I will soon be installing with a Limited bumper. I want the aux lights to be always on with both the low and high headlamp beams, so I don't have to have another switch in the dash. I have 10A inline fuses for the headlamp high and low beam circuits (2x55W bulbs=9.2A), and when the fogs are installed they will get a pair of 10A fuses (plus homemade lexan rock shields).
The new wiring setup will pull both pos and neg straight from the battery connectors, just personal preference to go that route. All wiring will be 10 or 12 gauge depending. It should leave all stock wiring intact should I choose to revert, take the load off the switches since they'll only be operating the relays, add fuses for safety, and be easily expandable.
I am using new high-temp bulb connectors and going from 9004XVs on 12.8V to 9007XVs on 14.4V (running voltage). I don't mind the consequent 75% decrease in lifespan; I figure I should still get at least 90 hours out of each pair of bulbs which is fine with me. With 9004 to 9007 netting a 30% light increase, and an additional 50% output from the overvoltage, plus a couple 55W aux lights on the bumper, this thing should light up the night for cheap. I bought a 3M lens resurfacing kit too.
A wiring diagram I drew up is attached - I have all the parts (except aux lights), just need to start putting them together. Any input is welcome or if you see anything I did wrong please let me know. If nobody says it won't work, I'll start assembly tomorrow
