Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
Ford Explorer Forums
Hi all,
Frustration has set in and any advice is appreciated. I have a 98 Explorer AWD 5.0 XLT Auto Trans 110,000 miles stock with a K&N air filter.
The problem started back in June with the CEL coming on occasionally but going off usually within 24 hours. Because everthing was OEM, I changed the plugs and wires, crossed 2 wires and got a backfire and CEL light on permanently. Quickly got the wires right and CEL stayed on. Pulled codes and it told me it was a bank 2 O2 sensor, replaced both, reset computer and light comes on again within 100 miles. Pulled codes- you guessed it- Bank 1 O2 sensor- replaced both-reset computer. Runs great for about 100 miles then light comes on. Getting ticked off now so take it to a Ford Master mechanic. His computer diagnosis says it's a lean condition and most likely One of the intake gaskets. Pain in the arse job so I replace both upper and lower gaskets, PCV and all vacume lines. Reset Computer. Runs great for about 100 miles CEL comes on. Now I am getting the following codes:
P0102 System too rich
P1000 Systems readiness test not complete
O1260 Theft detected Immobilizer
Thank you,
Brad
Thank you,
Brad
